  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
  • Service
  • Videos
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
    • Mill Toolholding Shop All
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
    • Mill Workholding Shop All
      • Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling Shop All
      • Indexable Milling Kits
      • Complete Indexable End Mill Kits
      • Burrs
    • Lathe Tooling Shop All
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • Broaching Toolholders
    • Lathe Toolholding Shop All
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
    • Lathe Workholding Shop All
      • Spindle Liners
      • Lathe Collet Chucks
    • ER Collets & Chucks Shop All
      • ER Collets
      • Tap Collets
      • Straight Shank Keyless Drill Chucks
    • Holemaking Shop All
    • Threading Shop All
    • Tool Management Shop All
    • Tooling Accessories Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
    • Package Kits Shop All
    • Apparel & Accessories Shop All
    • Storage & Handling Shop All
    • Measuring & Inspection Shop All
      • 7-Piece Measuring Kit
      • 3D Sensor Kit, Inch, CT40
      • 3D Sensor Kit, Metric, SK40/DIN
      • 3D Sensor Kit, Metric, BT40
      • 3D Sensor Kit, Inch, HSK63A
      • 3D Sensor Kit, Metric, HSK63A
      • 3D Sensor, Inch
      • 3D Sensor, Metric
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
    • Automatic Pallet Changer Shop All
    • Lathe Turret Shop All
    • Tool Changer Shop All
    • Chip Management Shop All
    • Coolant Shop All
    • Counterbalance Shop All
    • Electrical Cabinet Shop All
    • Enclosure Shop All
    • Hydraulics Shop All
    • Lubrication Shop All
    • Maintenance Shop All
    • Pendant Shop All
    • Probing Shop All
    • Rotary Shop All
    • Spindles Shop All
    • Tailstock Shop All
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
CL-1 Clamp Force
Service Home Service Updates CL-1 Clamp Force
July 30, 2018 CL-1 Clamp Force
  • Problem:
    • Excessive vibration has shown to be a cause in the loosening up of collet clamping force and poor surface finish.
  • Solution:
    • A primary check of the runout of the spindle drawbar assembly components is recommended.
      • It should be trammed in within .0003 TIR.
    • Remove the drawbar assembly and align the drawbar adapter [1] to 0.0003" TIR on the I.D.
    • Install the drawbar assembly and test.
    • For more detailed instructions, refer to the collet closer replacement instructions: AD0399.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
