Lathe Lubrication System Fitting Update
Service Home Service Updates Lathe Lubrication System Fitting Update
December 01, 2022 Lathe Lubrication System Fitting Update
With the change over to Haas Axis Lubrication Oil from HLG, there are additional fittings that will need to be added to Lathe machines to aid oil flow.
All Lathes will need to add an extra check valve and nipple fitting to the x-axis lubrication line. Additionally Lathes that also have a y-axis will need to add a check valve and nipple fitting to the y-axis lubrication system.
To do this order one (1) of the 93-3610: LATHE HLG TO OIL CONVERSION SVC KIT for every lathe converted over to Haas Axis Lubrication Oil from HLG. Lathes that also have a y-axis will need to order two (2) of 93-3610: LATHE HLG TO OIL CONVERSION SVC KIT.
Refer to the Haas Axis Lubrication Oil - Conversion procedure for where and how the fittings are installed.
