Rotary Motor Enclosure/Cable Change
Service Home Service Updates Rotary Motor Enclosure/Cable Change
June 22, 2018 - Rotary Motor Enclosure/Cable Change
The mounting screws [1] for the rotary cable connections have changed. They changed from 8-32 to 10-32 size screws. If you are replacing an enclosure on a rotary and receive the new version you must drill open the cable J-Box mounting holes to approximately .200" and use new hardware to mount the cable, 40-16205 10-32 X 1 3/4 & 45-1737 #10 Washer.
If installing a new cable that has the larger holes on an older enclosure make sure to properly seal the bolt holes with RTV.
Here is a list of enclosures that have changed:
25-4816A HRT210
25-4817A HRT310
25-4841A HRT160SP
25-4843A HRT210SP
