      • Fiber Laser
      • VF-4SS
      • 00-0012
ER STRAIGHT-BORE COLLETS
HAAS TESTED. HAAS PROVEN.
  2. ER Collets & Chucks
  3. ER Straight-Bore Collets
ER COLLETS OVERVIEW
ER Collets
  • Collets are available individually or in kits
  • Collet series is determined by the toolholder ER-taper size (11, 16, 20, 25, 32, 40)
  • Collet bore diameter is determined by the cutting tool shank diameter
ER Straight-Bore Collets – Features
NOTE: These collets have a clamping range. Use the tightest collet available for any given tool shank, to provide the greatest tool-to-collet contact area while minimizing runout.
In the case of a Ø12.2 mm tool, do not use a Ø12–11 mm collet. Instead, use a Ø12.5–11.5 mm collet. For general cutting applications, a Ø13–12 mm collet is usable.
  • Can be used to hold any type of round shank tool
  • Flexibility to clamp a wide range of tool shanks
  • High accuracy and concentricity
Clamping Range:
ER8:     0.5 – 5mm
             0.012 – 0.187"
ER11:   0.5 – 8mm
             0.043 – 0.281"
ER16:   0.5 – 10mm
             0.043 – 0.375”
ER20:   0.5 – 12mm
             0.043 – 0.5”
ER25:   1 – 16mm
             0.086 – 0.625”
ER32:   2 – 20mm
             0.086 – 0.781”
ER40:   2 – 26mm
             0.086 – 1”
ER Sealed Collets – Features
NOTE: Collet bore is the exact diameter of the tool shank. These collets have no clamping range.
  • Fits all Haas ER collet chuck holders
  • Ensures 100% of through-tool/spindle coolant gets to the tip of the cutting tool
  • Approved for high-pressure coolant to 1100 psi
  • Short rear collet slots provide a mechanical seal, blocking coolant flow
  • Mechanical seal design is superior to silicone/rubber sealed collets
  • Do not require a coolant ring or special ER nut
  • To seal properly, the entire tool shank must be in the collet and cover all slots
ER Tap Collets – Features
  • Collet bore is the exact tool diameter, with a square drive
  • Special design locks flat-sided tap shanks into the collet
  • Provides maximum concentricity, with positive driving force
  • Reduces tapping clearance requirements
Toolholder and Pull Stud specifications
Toolholder Maintenance
ER COLLETS RUNOUT TOLERANCE
DIN ISO 15488 specifies the dimensions, materials and manufacturing requirements, and designation of collets (of form A or of form B) for tools with cylindrical shanks and their corresponding holders and nuts. All Haas ER collets are manufactured to meet or exceed these requirements.
    Form A: 6 to 8 slots.
    Form B: 12 to 16 slots.
This International Standard also specifies collet runout tolerances. These tolerances are checked as is shown in the figure below, by the introduction of a test mandrel into the collet. The diameter of the test mandrel is the nominal diameter of the collet.
For the test mandrel, the following specifications apply:
    a) diameter tolerance: h6;
    b) cylindricity: 0.002mm;
    c) parallelism: 0.002mm;
    d) roundness: 0.002mm;
    e) surface without longitudinal marks;
    f) maximum surface roughness Rz = 4µm;
    g) surface hardness: (58 +3/-0) HRC.
Dimensions in millimeters
d
H7
Nominal Diameter
L
Runout Tolerance (a)
Above
Up To (Included)
Class 1 (b)
Class 2
1 (Included)
1.6
0.01
0.015
1.6
16
25
18
40
0.015
0.020
18
26
50
 a     Normal style collets are designed with runout tolerance class 2. If class 1 is required, it shall be given separately.
 b     In the case of applications where runout tolerances class 1 are required, the accuracy of the whole system (machine tool spindle, holder, collet, and tool) shall be observed.
