      • Fiber Laser
      • VF-4SS
      • 00-0012
CERMET TURNING INSERTS
HAAS TESTED. HAAS PROVEN.
SEE ALL CERMET TURNING INSERTS
  2. Lathe Tooling
  3. Cermet Turning Inserts
CERMET TURNING INSERTS OVERVIEW
PVD coated cermet turning inserts are an enhancement to our general turning inserts, designed specifically for high-speed finishing. These inserts allow faster cutting speeds, with less deterioration and wear, than our CVD carbide inserts, during uninterrupted cutting.
The HCP10C coated cermet grade was engineered to provide improved stability in continuous turning applications at high speeds and low depths of cut. Wear resistance has been significantly improved, and crater wear on the rake surface of the insert is largely prevented during continuous machining of carbon steel and alloy steel. The highly lubricative PVD coating layer provides excellent wear resistance and extended tool life.
APPLICATIONS:
  • Continuous cutting of carbon steels, alloy steels, and cast iron
  • High-speed and finish turning
BENEFITS:
  • High resistance to chipping and thermal cracking
  • High wear resistance
  • Excellent surface finishes
  • Increased tool life
FEATURES:
  • Uniform micro-grain substrate resists chipping and thermal cracking
  • Optimized cutting edge improves surface finish
  • Improved stability at high speeds and when finishing
Cermet Insert Grades
APPLICABLE WORKPIECE MATERIALS
N - ALUMINUM / NON-FERROUS
S - HIGH-TEMP ALLOYS
HCP10C
Cermet Insert Chipbreakers
HF – Finishing
For finishing, with excellent chip evacuation in continuous high-speed machining of various workpieces, lower cutting resistance, high rigidity of the cutting edge, and longer tool life. stable chip control in copying and internal machining.
INSERT STYLES
  • Insert Styles
  • Chip Breakers
  • Insert Grades
Insert Styles
C-Style Inserts – 80° Rhombic
For external machining and facing. The large point angle is very rigid, and good for rough machining. This is the most commonly used insert.
D-Style Inserts – 55° Rhombic
The smaller point angle of this insert is more versatile for finishing and detail work, but it has less cutting-edge strength than other geometries.
V-Style Inserts – 35° Rhombic
T-Style Inserts – 60° Triangle
For internal machining. The 60° cutting angle provides medium cutting-edge strength that allows for both ID roughing and finishing applications.
W-Style Inserts – 80° Trigon
This insert has 3 cutting edges per side. The 80° cutting angle provides high cutting-edge strength for roughing, but the depth of cut is limited by the short cutting edge.
LARGE NOSE ANGLE
• Stronger cutting edge
• Higher cutting forces
• More vibration
• Higher feedrates
SMALL NOSE ANGLE
• Better access to features
• Lower cutting forces
• Weaker cutting edge
• Lower vibrations
CLAMPING STYLES
Clamping Styles
M – Multi-Lock System*
• For negative-style inserts
P – Lever-Lock System
S – Screw-On System
• For positive-style inserts
D – Double-Clamp System
• Powerful single-lever screw clamping
• Spring design releases clamp automatically
• Optimized for chip flow
• Eccentric lock pin secures the insert against the side
• Top clamp provides rigid downward clamping
S – Screw-On System
* For multi-lock holders: Rotate the eccentric lock pin counterclockwise until the insert drops on, and then rotate the eccentric pin clockwise to secure the insert against the side of the holder. Install the top clamp to hold down the insert.
INSERT CUTTING DEMOS
