GROOVING & CUT-OFF TOOLS
HAAS TESTED. HAAS PROVEN.
SEE ALL GROOVING TOOLS
  2. Lathe Tooling
  3. Grooving & Cut-Off Tools
GROOVING TOOLS OVERVIEW
Grooving Tools – Guidelines:
Haas Grooving Tools can be used for grooving, parting-off, facing, as well as general turning operations. These versatile tools use allow the machinist to use a single tool for many applications, reducing the number of tools in the turret, and the number of necessary tool changes.
The carbide inserts are reversible, with two cutting edges for more economical machining. The flat geometry of the cutting edge and wiper function of the insert ensure excellent surface finishes, even at high feedrates.
Advantages:
  • Suitable for grooving, facing, face grooving, parting-off, and general turning
  • Strong clamping system ensures stable and accurate machining
  • A single tool can be used for multiple applications
  • Replaceable carbide inserts for economical machining
  • Available for external (OD) and internal (ID) applications
Selecting the Correct Grooving Tool/Insert:
Haas Grooving Tools are defined by the following requirements:
  • Lathe turret/tooling size
  • External (OD) or internal (ID) machining
  • Required cutting depth (T-max)
  • Insert cutting width
  • Insert style
Insert Features:
  • All inserts are made from high-quality cemented carbide and are TiAlN (Titanium Aluminum Nitride) PVD coated for high wear resistance and lower friction, as well as higher cutting feeds and speeds
  • HU30 and HUU20P grades for Steel, Stainless, and Cast Iron with the option to use on Aluminum and Non-Ferrous Alloys
The chart below highlights the various styles of Haas Grooving Inserts. Use the appropriate filters to select the parameters that best correspond to your specific grooving application.
Sale Items( 1 )
System of Measurement( 3 )
Tool Or Insert( 2 )
Tool Orientation( 2 )
Insert Style( 5 )
[H] Shank Height( 8 )
[CW] Cutting Width( 4 )
[T-MAX] Maximum Depth( 15 )
Through Tool Coolant( 2 )
[ØD] Min. Machining Diameter( 9 )
[ØDMM] Shank Diameter( 8 )
63 items
01-0134
HGER08-2, 1/2" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 2
Part #: 01-0134
RETAIL PRICE:
56.97
01-0135
HGER12-2, 3/4" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 2
Part #: 01-0135
RETAIL PRICE:
56.97
01-0136
HGER16-2, 1" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 2
Part #: 01-0136
RETAIL PRICE:
61.97
01-0137
HGER12-3, 3/4" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 3
Part #: 01-0137
RETAIL PRICE:
57.97
01-0138
HGER16-3, 1" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 3
Part #: 01-0138
RETAIL PRICE:
62.97
01-0139
HGER20-3, 1-1/4" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 3
Part #: 01-0139
RETAIL PRICE:
66.97
01-0140
HGER16-4, 1" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 4
Part #: 01-0140
RETAIL PRICE:
61.97
01-0141
HGER20-4, 1-1/4" Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 4
Part #: 01-0141
RETAIL PRICE:
60.97
01-0142
HGIR12-10-2, 5/8" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 2, Through-Tool Coolant
Part #: 01-0142
RETAIL PRICE:
56.97
01-0143
HGIR16-12-2, 3/4" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 2, Through-Tool Coolant
Part #: 01-0143
RETAIL PRICE:
63.97
01-0144
HGIR20-16-2, 1" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 2, Through-Tool Coolant
Part #: 01-0144
RETAIL PRICE:
75.97
01-0145
HGIR16-12-3, 3/4" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 3, Through-Tool Coolant
Part #: 01-0145
RETAIL PRICE:
68.97
01-0146
HGIR20-16-3, 1" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 3, Through-Tool Coolant
Part #: 01-0146
RETAIL PRICE:
75.97
01-0147
HGIR24-20-3, 1-1/4" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 3, Through-Tool Coolant
Part #: 01-0147
RETAIL PRICE:
85.97
01-0148
HGIR20-16-4, 1" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 4, Through-Tool Coolant
Part #: 01-0148
RETAIL PRICE:
75.97
01-0149
HGIR24-20-4, 1-1/4" Ø Steel Shank Internal (ID) Grooving Bar, Right-Hand, Insert Size 4, Through-Tool Coolant
Part #: 01-0149
RETAIL PRICE:
85.97
01-0456
HGER1212-2, 12mm Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 2
Part #: 01-0456
RETAIL PRICE:
77.97
1049.97
312.97
41.97
188.97
440.97
01-0457
HGER2020-2, 20mm Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 2
Part #: 01-0457
RETAIL PRICE:
84.97
1049.97
312.97
41.97
188.97
440.97
01-0458
HGER2525-2, 25mm Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 2
Part #: 01-0458
RETAIL PRICE:
92.97
1124.97
334.97
44.97
202.97
472.97
01-0459
HGER2020-3, 20mm Square Steel Shank External (OD) Grooving Tool, Right-Hand, Insert Size 3
Part #: 01-0459
RETAIL PRICE:
84.97
