      • Fiber Laser
      • VF-4SS
LIVE CENTERS
HAAS TESTED. HAAS PROVEN.
SEE ALL LIVE CENTERS
  2. Lathe Workholding
  3. Live Centers
HIGH-SPEED, HIGH-PERFORMANCE LIVE CENTERS
High-Speed, High-Performance Live Centers
A live center provides additional support for long, large, or heavy parts during turning operations. The live center is installed in the nose of the tailstock using a Morse taper connection, and then brought forward to contact the centerline of the part. The 60° hardened-steel point of the live center engages with a corresponding 60° countersink in the end of the material, thus supporting the free end of the part. A high-precision bearing assembly in the live center allows the unit to spin freely with the part, while allowing full tailstock support.
  • 60° standard steel point, heat-treated to HRc 60 ± 2
  • Accuracy guaranteed to 0.002 mm TIR (0.0001")
  • Excellent for high-speed CNC turning (up to 6000 rpm)
  • Double angular contact bearings for superior performance
  • Anti-friction seal for coolant deflection and high speed
  • Heat-treated body for extra strength, rigidity, and long life.
Which Live Center Should I Use?
There are 2 types of live center available for each size of Morse Taper (MT), from 3 to 5.
Standard point: For general workholding
Extended point: For improved tool clearance
LIVE CENTER MACHINE FIT GUIDE
FIND THE RIGHT LIVE CENTER FOR YOUR MACHINE
This chart applies to compatible Y-axis and Long-bed machine models
*5MT size tailstock is standard on these machines, but the 6MT size tailstock option is available on these machines. 6MT live centers are currently unavailable on Haas Tooling. The ST-50 and ST-55 use 6MT size tailstocks as standard.
