MILLING CHUCKS AND COLLETS
HAAS TESTED. HAAS PROVEN.
  2. Mill Toolholding
  3. Hydraulic Milling Chucks & Collets
HYDRAULIC MILLING CHUCKS
Hydraulic Chuck Toolholders provide high grip strength, and allow easy tool changeovers. They contain hydraulic fluid, which is compressed by tightening a set screw to provide equal pressure around the tool and secure it in place.
Hydraulic chucks are designed to hold a single size tool shank, and then precision straight-shank reducing collets are used to hold smaller diameter tools. The straight collet design provides even clamping along the entire length of the shank, eliminating axial movement of the tool, increasing rigidity, and minimizing runout. This results in better surface finishes and longer tool life, as well as high gripping force for heavy milling.
Easy-to-use set screw tightening, paired with high holding pressure and low runout, make hydraulic chucks great for general-purpose and precision machining.
WHY USE A HYDRAULIC MILLING CHUCK?
BENEFITS:
  • Very low runout (~.00012" TIR)
  • Faster tool changeovers
  • Longer tool life
  • High grip force
  • Excellent damping
APPLICATIONS:
  • High-accuracy machining
  • High-volume production
  • High-spindle speeds and feed rates
  • Milling
  • Drilling
  • Reaming
  • Tapping
  • Thread milling
Sale Items( 1 )
System of Measurement( 2 )
Item( 2 )
Taper( 6 )
[ØD] Bore Diameter( 20 )
[ØBD] Body Diameter( 11 )
33 items
04-0920
BT40 25mm Hydraulic Chuck x 83mm Gage Length, TSC
Part #: 04-0920
RETAIL PRICE: $288.95 $6,498.95 $1,934.95 $259.95 $1,169.95 $2,729.95 $undefined
$187.97
4549.97
1353.97
181.97
818.97
1910.97
04-0921
SK40 25mm Hydraulic Chuck x 80.5mm Gage Length, TSC
Part #: 04-0921
$187.97
4549.97
1353.97
181.97
818.97
1910.97
04-0922
CT40 1" Hydraulic Chuck x 3.25" Gage Length TSC
Part #: 04-0922
RETAIL PRICE: $288.95 $undefined
$216.97
04-0923
CT50 1" Hydraulic Chuck x 3.54" Gage Length TSC
Part #: 04-0923
RETAIL PRICE: $398.95 $undefined
$279.97
04-0924
HSK63A 25mm Hydraulic Chuck x 120mm Gage Length, TSC
Part #: 04-0924
RETAIL PRICE: $440.95 $9,998.95 $2,975.95 $399.95 $1,799.95 $4,199.95 $undefined
$308.97
6999.97
2082.97
279.97
1259.97
2939.97
04-0925
HSK63A 1" Hydraulic Chuck x 4.72" Gage Length TSC
Part #: 04-0925
RETAIL PRICE: $440.95 $undefined
$308.97
04-0926
Hydraulic Chuck Collet, 4mm Bore Diameter x 25mm External Diameter
Part #: 04-0926
RETAIL PRICE: $80.95 $1,748.95 $520.95 $69.95 $314.95 $734.95 $undefined
$52.97
1224.97
364.97
48.97
220.97
514.97
04-0927
Hydraulic Chuck Collet, 5mm Bore Diameter x 25mm External Diameter
Part #: 04-0927
$52.97
1224.97
364.97
48.97
220.97
514.97
04-0928
Hydraulic Chuck Collet, 6mm Bore Diameter x 25mm External Diameter
Part #: 04-0928
$52.97
1224.97
364.97
48.97
220.97
514.97
04-0929
Hydraulic Chuck Collet, 8mm Bore Diameter x 25mm External Diameter
Part #: 04-0929
$52.97
1224.97
364.97
48.97
220.97
514.97
04-0930
Hydraulic Chuck Collet, 10mm Bore Diameter x 25mm External Diameter
Part #: 04-0930
1224.97
364.97
48.97
220.97
514.97
04-0931
Hydraulic Chuck Collet, 12mm Bore Diameter x 25mm External Diameter
Part #: 04-0931
$48.97
1224.97
364.97
48.97
220.97
514.97
04-0932
Hydraulic Chuck Collet, 14mm Bore Diameter x 25mm External Diameter
Part #: 04-0932
$52.97
1224.97
364.97
48.97
220.97
514.97
04-0933
Hydraulic Chuck Collet, 16mm Bore Diameter x 25mm External Diameter
Part #: 04-0933
$52.97
1224.97
364.97
48.97
220.97
514.97
04-0934
Hydraulic Chuck Collet, 20mm Bore Diameter x 25mm External Diameter
Part #: 04-0934
$48.97
1224.97
364.97
48.97
220.97
514.97
04-0935
Hydraulic Chuck Collet, 1/8" Bore Diameter x 1" External Diameter
Part #: 04-0935
RETAIL PRICE: $80.95 $undefined
$48.97
04-0936
Hydraulic Chuck Collet, 3/16" Bore Diameter x 1" External Diameter
Part #: 04-0936
$48.97
04-0937
Hydraulic Chuck Collet, 1/4" Bore Diameter x 1" External Diameter
Part #: 04-0937
$48.97
04-0938
Hydraulic Chuck Collet, 5/16" Bore Diameter x 1" External Diameter
Part #: 04-0938
$48.97
04-0939
Hydraulic Chuck Collet, 3/8" Bore Diameter x 1" External Diameter
Part #: 04-0939
$48.97
