LASER MARKING MACHINES OVERVIEW
Fiber Laser Marking Machines
Laser marking machines utilize advanced photonics to offer precise laser marking and engraving capabilities to your production line. Fiber laser marking machines are equipped with an optical fiber cable instead of the typical series of lenses to concentrate and amplify the high-output, diode-generated light through a converging lens. The resulting laser beam is straighter, smaller, and more precise than other types of laser marking machines, with greater electrical efficiency and comparatively low operating costs.
These machines are generally suitable for most metallic materials and alloys, such as steel, stainless steel, brass, aluminum, silver, and iron, as well as some non-metallic materials, allowing it to be applicable across a wide range of industries – ideal for small and large manufacturing operations alike.
The HL50E is a complete fiber laser marking solution that includes everything you need to etch and mark materials in your shop – all in a mobile, easy-to-setup package. Includes a lifetime license to LightBurn Software.
Features
  • Q-Switch Pump Source – efficiently emits light in rapid bursts/pulses, for better thermal control
  • Laser Pointers – ensures marker is in focus once calibrated
  • Integrated Fume Extractor – automatically extracts harmful fumes produced by lasering
  • 450 x 350mm Standard Fixture Plate
  • Laser Light-Safe Windows
  • Power and Manual Laser Head Height Adjustment
  • Foot Switch
  • Integrated Windows 11 PC
  • Includes a lifetime license to LightBurn Software
  • Includes a 12-month warranty from ship date supported by your local Haas Factory Outlet
  • (2) Laser Lenses Included:
    • F160 Lens: 110 x 110mm (~4" x 4") working area, 160mm focal length (default)
    • F290 Lens: 200 x 200mm (~8" x 8" working area, 290mm focal length
Laser Rotary Fixtures
These laser rotary fixtures are designed for hassle-free installation on Haas Laser Marking Machines, due to the standard 4-pin aviation plug. This connection allows for quick plug-and-play setup, eliminating complex wiring or additional configuration steps. Simply enable the rotary function within Lightburn, connect the plug, and you're ready to start marking!
ATTENTION! Haas laser marking machines are equipped with an integrated fume extractor designed to remove harmful fumes and particulates generated during laser operation. Additionally, the machines feature laser safety windows to filter hazardous light rays. Operating the machine without the factory-provided fume extractor or with the laser safety windows unlocked and open may pose serious health and safety risks due to exposure to fumes, particulates, and/or harmful light rays.
  2. Shop Support
  3. Laser Marking Machines
