Inserti di brocciatura
  3. Collari di maschiatura ER
  4. Collare di maschiatura ER16 #10, Diametro alesaggio 0,194" x 0,152" quadrato
04-0105
N. pezzo: 04-0105
ER16 TAP COLLET #10
Valutazione del cliente:
Prezzo: $23.95 ( / unità)
Questo collare per maschiatura ER16 per maschi in pollici N. 10 ha un attacco quadrato incorporato per afferrare saldamente il codolo del maschio a lato piatto per fornire la coppia extra richiesta per la maschiatura.
  • Modello 3D (ZIP)
Serie collare ER-16
Tipo Collare maschiatura
Dimensione maschiatura #10
[ØD] Diametro alesaggio 0,194 pollici
[LSC] Lunghezza di serraggio 0,591 pollici
[SS] Dimensione quadrato 0,152 in
Peso 0,1 lbs \ 0,1 kg
Paese d'origine Cina
04-0105
articoli
Valutazioni medie dei clienti:
4.8
Recensioni totali: 4
Alexander
01/01/2025
Perfect for the job
Fits 10-32 taps. Less slip and more torque to the tap
Scott J
06/06/2024
Great quality
Works great in holder
kae
03/15/2021
dedicated setups
keeping holders setup with my standard taps is priceless! these are great!
Joseph Soliman
03/02/2021
only 1 downside
This #10 tap collet also works with M5 taps. It holds the tap extremely well. I gave this 4 stars because it wouldn't fit in my Maritool ER16 holder with standard nut, and I had to use a different holder (no big deal). I verified that it works with Haas and Technik tool holder nuts. This is likely due to the design that Maritool has on the inside of the nut where it sits in the groove of the collet, or maybe the OD of the collet may be bigger than normal. Other than that, a great collet for my tap.
04-0105
04-0105
