Inserti di brocciatura
  2. Serraggio dei pezzi fresatrice
  3. Vise Kits
  4. Kit serraggio dei pezzi per fresatrice, morsa manuale 6", CT40
08-0170
08-0170
08-0170
08-0170
08-0170
08-0170
08-0170
N. pezzo: 08-0170
Mill Workholding Starter Kit
Prezzo: 1099.95 ( / unità)
1044.97
SETUPS MADE EASY
______________________________________________
BENEFITS:
This Mill Workholding Kit includes everything you need for basic workholding on a standard T-slot table. It contains a Single-Station Fixed-Jaw Vise, Toe Clamp Kit, Toolholder Fixture/Vise, and Machinable Soft Jaws.
The Single-Station Fixed-Jaw Vise is a flange-style vise that features a cast-in stationary jaw for less deflection and more stability during clamping. The proprietary AngLock® design ensures alignment of the moving jaw and reduces jaw lift for superior performance. The bolt-on jaws are easily changed or reversed, and machinable steel and aluminum soft jaws are available.
The Toe Clamp Kit Is a versatile kit that contains a wide range of clamping components of different lengths and sizes. Giving you an extensive range of options to clamp your parts, fixtures, or workholding securely to the mill table.
The Haas Toolholder Fixture provides a safe, easy, and secure way to securely tighten your pull studs and cutting tools into your toolholders. Featuring a lightweight cast iron body, with a compact design that mounts easily to a worktable or tool cart.
The Soft Steel and Aluminum Machinable Vise Jaws are easily machined to the shape of your part for custom workholding applications.
This Kit Contains:
  • Haas Workholding by Kurt 6" Single-Station Fixed-Jaw Vise
  • Haas CT40 (SK40/DIN) Toolholder Fixture/Vise
  • Toe Clamp Kit for 5/8" T-Slot Tables
  • Aluminum and Soft Steel Machinable Vise Jaws
Haas Ready2Run Mill Workholding Kit
All your workholding needs in one kit! The Ready2Run workholding Kit features a 6" Kurt vise, 58 pc toe clamp kit, 4 sets of machinable vise jaws, plus a sturdy bench-top 40-taper vise.
  • Clamp Force Graph
  • KURT LIFETIME WARRANTY
HAI PULITO LA MORSA DI RECENTE?
Mantieni la morsa in funzione senza intoppi! Scopri come pulire e mantenere la morsa.
08-0170
08-0170
08-0170
08-0170
08-0170
08-0170
08-0170
