Variable Flow Coolant Pump (VARIABLE FLOW CLNT)
Product Image
GET QUOTE
    CNY ONLY
Control coolant flow via M-code
  • Option Info
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
Our Variable Flow Coolant Pump uses a variable frequency drive to control the speed of our standard centrifugal coolant pump during operation. This allows control of the coolant flow and pressure directly from the program, via M code and P values.
NOTE: Not compatible with the High-Pressure Flood Coolant option (HIGH PRESSURE COOL).
  • Adjustable for low, standard, and high flow
  • Controlled by M code, using P values
  • Unaffected by the incoming power frequency
The variable flow coolant option allows the user to operate the coolant pump at different speeds to increase or decrease the flow of coolant. An optional P-code can be specified along with an M08 to change the speed of the coolant pump.
  • P0 = Low Pressure – the pump will operate at 50Hz speed
  • P1 = Normal Pressure – the pump will operate at 60Hz speed
  • P2 = High Pressure – the pump will operate at 80Hz speed
Service Documents
Available on These Machines
Need More Information?
