Electronic Handwheels (E-HANDWHEELS)
Product Image
GET QUOTE
    CNY ONLY
Provides the feel of conventional handwheels on your Haas Toolroom lathe
  • Overview
  • Send Info
The E-Handwheels for the TL Series effectively bridge the gap between manual machining and CNC. The jog wheels are placed at offset heights to mimic the feel of a manual engine lathe. With the E-Handwheels, you can cut an entire part manually, or quickly jog around to set up a CNC program. A magnetic base allows you to place the E-Handwheels pendant wherever it is comfortable for you, and the Haas control displays a digital read out (DRO) of position when in Handle Jog mode.
  • X and Z electronic jog wheels
  • X and Z power feed
  • Rapid mode
  • Adjustable dial for setting jog increments
  • Infinitely adjustable dial for setting feedrates
Need to install the E-Handwheel on your TL? Check out the Installation Guide!
INSTALLATION GUIDE
Do you like the ease of using handwheels to perform basic turning operations? The E-Handwheels option for Haas TL series Toolroom Lathes gives you precise, easy, “manual” control of both axes for positioning, cutting, and more. You can also perform feed or rapid moves using the jog buttons, adjust your feed-per-rev, set your jog increments, and even chamfer – all from the E-Handwheels unit. And because the unit has powerful magnets for mounting, you can place the E-Handwheels anywhere on the machine!
Need More Information?
