    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Fixture Clamps
      • Toolmakers Vise
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Plug & Ring Gauges
      • Gauge Blocks & Accessories
      • Pin Gauges & Accessories
      • Test Bars
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
7.5k Spindle, 60 hp (7.5K-50T-HP)
Product Image
GET QUOTE
High-Performance 7500-rpm Spindle
    CNY ONLY
High-power spindle for 50-taper VF and EC Series
  • 7.5k Speed
  • 50 Taper
  • 60 hp Power
  • Option Info
  • Torque CHart
  • Specs
OVERVIEW
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
This high-performance 7500-rpm spindle for 50-taper machines is driven by a 60 hp vector drive system that provides higher power throughout the rpm range than the standard spindle. It uses a Haas-built two-speed gearbox to provide a wide constant horsepower band, good low-speed torque for heavy cuts, and higher torque throughout the range above 500 rpm. Haas gears are CNC machined and hobbed out of alloy steel, heat treated to 60 Rc, and then precision ground to AGMA Class 13 quality.
  • 60 horsepower (peak) vector drive system
  • 2-speed gearbox designed, manufactured, and built in-house
  • More power than the standard spindle for larger diameter tools and tougher materials
  • Automatic High or Low gear selection, based on commanded rpm
  • User-programmable selection of High or Low gear selection via M-codes
Service Documents
High-Performance 50-Taper Spindle
Do you need to increase your material removal rates? Our high-performance 50-taper spindle options use a powerful 60 hp vector drive system to push the boundaries to new limits. If you want to cut more chips in less time, watch now to see how we can maximize your material removal rates!
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 15 minutes, 100% spindle load (50% of the peak number) continuously.
Spindle S.A.E METRIC
Max Rating 60.0 hp 44.7 kW
Max Speed 7500 rpm 7500 rpm
Max Torque 350.0 ft-lbf @ 900 rpm 475.0 Nm @ 900 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Taper CT or BT 50 CT or BT 50
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Spindle Power 60.0 hp 44.7 kW
Full Load Amps (3 Phase) - Low 105 A 105 A
Need More Information?
Note: The optional high-performance spindles have a higher power requirement than the standard spindle. Contact your local HFO for information.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
