320V Power Supply Replacement - (93-69-2000E) - AD0421
Service Home How To Procedures 320V Power Supply Replacement - (93-69-2000E) - AD0421
Recently Updated Last updated: 01/31/2022
AD0421
- Jump to Section - 1. Introduction 2. Electrical Safety 3. Replacement / Installation Back to Top
This procedure will show you how to replace P/N 93-69-2000E 320V Power Supply on a Classic Haas Control.
This Document Applies to these Parts:
  • 93-69-2000E
Electrical Safety
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
  1. [POWER OFF] the machine  and wait until the High Volt light is completely turned off.
  2. Mark and remove all the cables from the 320V Power supply.
    Note:  The new 320V Power Supply [1] does not need the +12VDC supply that was connected to J3 on the old power supply.
  3. Install the new 320V Power Supply [1].
  4. Install and connect the PS Fault cable that comes in the kit to J4 [2].
  5. Connect the VMON cable to J2 [3].
    Note: Older machines did not have a VMON cable installed.  For these machines the VMON cable is not used.
  6. Connect the Regen cable [4] to the terminal strip.
  7. Connect the 320VDC cable [5] to the terminal strip.
  8. Connect the 230VAC Input cable [6] to the terminal strip.
  9. Connect the Ground cable and make sure all terminals are tight.  [POWER ON] and test the machine operation.
