Air Gun and Hose - Installation - AD0120
Service Home How To Procedures Air Gun and Hose - Installation - AD0120
Recently Updated Last updated: 03/25/2024
AD0120
- Jump to Section - 1. Introduction 2. Installation (2 steps) 3. Replacement (2 steps) 4. Verification Back to Top
This procedure will show how to install an Air Gun or Hose.
  • 93-30-11547 AIR HOSE STRAIGHT KIT SVC
 Note: A spare air gun assembly will be included in the 93-30-11547 service kits after July 9, 2024.
Press [POWER OFF].
Close the primary air valve [1].
Pull the ring on the pressure-relief valve [2] on the air/lubrication manifold. This releases the air pressure from the system.
Disconnect the existing air hose from the machine if present.
Connect the air hose [2] to the air supply [1].
 Note: Some machines have the air supply under the glove box. Some machines can have the air supply in another location in front of the machine.
Replacement
Press [POWER OFF].
Remove old air gun from hose.
Attach the new air gun [1] to the fitting [2].
Verification
Turn on the air.
Examine all of the fittings for leaks.
Verify air comes out of air gun when trigger is engaged.
WARNING: Do not use pressureized air near face or on skin.
HIN, 3/32” Keyway Broaching Insert, D10 Clearance Fit, Size 2, TiN Coated - Pack of 2 $69.95 $52.97
DNMG433-HUR / DNMG150412-HUR, Carbide Turning Insert, 55° Rhombic, Grade HTSU10 - Pack of 5 $34.95 $24.97
ER11-A60 Carbide Threading Insert, Grade HTU20P - Pack of 10 $102.95 $0
