BMT45/65/75 Live Drive Turret Vibration Test
Service Home How To Procedures BMT45/65/75 Live Drive Turret Vibration Test
Recently Updated Last updated: 11/30/2023
This procedure requires the Octavis Vibration Analyzer and Software
- Jump to Section - 1. Vibration Displacement Test (3 steps) Back to Top
  • Install a live tool into any pocket
  • Press [MDI]
  • Press [ERASE PROGRAM] to clear any existing programs - save them beforehand if need be
  • Type "M133 P4000" or "M133 P6000" and press [ENTER]
Note: The live tooling should be programed to the maximum live tooling speed of the option purchased.
  • Install an empty live tool holder in tool #1. Install the accelerometer on the driven tool with the unit centered over axis of rotation to see maximum results.
 Note: The image shows two different accelerometers [1][2].
 Note: Image shown is a BMT65 Turret (left) and a BMT45 Turret (right). Setup will be similar for the BMT75.
  • Follow the procedure for setting up the Octavis software if need be - do not follow the spindle portion of the procedure:
    • Vibration Analysis - RS-232 Interface
    • Vibration Analysis - Ethernet Interface
  • To setup the axes for a Vibration Displacement Plot, do the following:
    • Right click on the plot and highlight Averages ► click on 8.
    • Right click on the plot and highlight X-Axis ► Unit ► click on CPM.
    • Right click on the plot and highlight Y-Axis ► Unit ► click on Vibration displacement.
    • Right click on the plot and highlight Y-Axis ► Scaling ► click on .1 mil.
    • Press the "Cycle Start" button on the control; the Octavis program will begin collecting data.
    • Once the 8 data points have been collected, press the copy button.
    • Press the "Reset" button on the control.
  • Tolerance not to exceed (NTE) 0.01 MIL of Vibration Displacement at 4000 or 6000 CPM [1]. This is dependent on the maximum live tooling speed.
  • If the live drive exceeds the tolerance - go to the following procedures for your live drive type
    • BMT45 Live Drive Troubleshooting Guide
    • BMT65 Live Drive Troubleshooting Guide
  • For reference when sending plots into the Service Department at Haas Automation, please also attached the Velocity Plots
  • To set up the axis for Velocity, do the the following:
    • Right click on the plot and highlight Averages ► click on 0 or none
    • Right click on the plot and highlight Y-Axis ► Unit ► click on Velocity
  • Press the copy button once the graph stabilizes to the most consistent reading
