High/Low Gear MAC to SMC Solenoid Replacement
Service Home How To Procedures High/Low Gear MAC to SMC Solenoid - Replacement
Recently Updated Last updated: 06/21/2019
- Jump to Section - 1. Introduction 2. Configure Solenoid Assembly (2 steps) Back to Top
This procedure will show you how you can re-arrange the High/Low Gear SMC solenoids to be compatible with the previous MAC solenoid configurations.
Re-arrange the solenoids on the manifold as shown.
  • Note the orientation of the High/Low Gear Shift solenoid.
  • Use the Phillips screwdriver and remove the High/Low Gear Shift solenoid and the cover plate from the manifold.
    Note: The rubber gaskets under the solenoid and the cover plate are identical and do not need to be swapped.
Reinstall the High/Low Gear Shift solenoid [1] in the same orientation as before on the left side of the manifold and the cover plate [2] on the right side.
This will allow the solenoid coil to line up with the cut-out on the mounting bracket.
Install the solenoid assembly back into the gearbox switch mounting bracket.
