RJH-XL Robot - Upgrade Kit - AD0552
Service Home How To Procedures Alarm Search: general.000.0000 RJH-XL Robot - Upgrade Kit - AD0552
Recently Updated Last updated: 10/28/2021
AD0552
- Jump to Section - 1. Introduction 2. Remote E-Stop Upgrade (2 steps) 3. Robot Electrical Interface Box Upgrade (2 steps) 4. RJH-XL - Electrical Installation 5. RJH-XL Verification (1 step) Back to Top
This procedure will show you how to upgrade your Robot installed with the RJH-T assembly to work with RJH-XL assembly. To install the RJH-XL follow the Remote Jog Handle - XL - Installation procedure.
Machine Requirements:
  • RJH-XL PN: 93-1000610
  • Next Generation Control Machine
  • Software version 100.21.000.1120 and higher
  • 34-4510 SKBIF FOR NGC W/ RJH-C/VID CCA
  • 6.6 SKBIF firmware
  • RA.03.06 RJH firmware and higher
  • Load the latest configuration files to enable the RJH-XL.
  • Jumpers JP2 and JP3 on the SKBIF need to be in the vertical position to enable the RJH-XL E-Stop.
 Warning: By not putting the jumpers in the vertical position, E-STOP functionality on the RJH-XL is disabled and the machine is considered unsafe. Jumpers MUST be inserted vertically.
Note: Use this procedure to update the SKBIF and RJH firmware: SKBIF PCB / RJH FIRMWARE UPDATE - NGC
This document applies to the following kits:
  • 93-1000713 - RJH-XL UPGRADE KIT HRP-1
  • 93-1000716 - RJH-XL UPGRADE KIT HRP-3 MILL
  • 93-1000717 - RJH-XL UPGRADE KIT HRP-3 LATHE
Note:  All the above software and firmware files can be downloaded from the Haas Business Center.
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
1. Remove the original front cover and Remote E-Stop box from the the fence.
2. Remove the cradle from the original front cover.
3. Install the cradle and cable 33-8550C to the upgrade front cover. Plug 33-0712 from the cradle into cable 33-8550C.
4. Install the Remote RJH box to the fence in the vertical orientation. Install the front cover to the RJH box.
Remove the jumpers JP2 and JP3 [1] on the SKBIF from the horizontal position and replace them in the vertical position.
1. Remove the front cover from the interface box.
2. Remove cable 33-8540B[1] from the front cover and disconnect cable 33-8561B[2] and remove the safety relay 32-8601[3] from the DIN rail.
3. Install the dome plug[4] into the E-Stop location on the front cover. Install cable 33-8540C[5] to the front cover. Install cable 33-8562C[6]. Install the 24V E-Stop Relays 32-0974[8] onto the DIN rail and then reinstall the safety relay 32-8601B[7] onto the DIN rail. Connect the cables to the matching connectors according to the Robot Electrical Interface Wiring Schematic.
4. Install the magnetic cable clamp[9] to secure the relay cables and reinstall the front cover.
1. 33-8631 E-STOP 24V RLYS 24VDC RLYS
2. 33-8628A SAFETY RLY SIG SAFETY RLY
3. 33-8561C HRP INTF TO I/O I/O PCB
4. 33-8561C  HRP INTF TO I/O I/O PCB RJ-45
5. Robot Signals connects to 33-8590A
6. Interlock connects to 33-0721
7. RJ-45 connects to 33-8590A
Perform the following steps to reconnect the robot to the Haas machine.
  • Remove the Normally Closed contactor P/N 61-0047A and Pendant E-stop extension cable P/N 33-8580 from the pendant E-Stop assembly.
Main Transformer
  • Connect cable [1] P/N 33-8570 to Main Transformer follow the labels to terminals 77 and 78,  connect the ground loop terminal to chassis.
I/O PCB and Maincon PCB
Cable P/N 33-8561C has multiple connections:
  • Connect the E-STOP terminal block connections  to SIO PCB TB-1B (see diagram)[2].
  • Reinstall the JP1 jumper.
  • Connect the Setup mode terminal block connections to SIO PCB TB-3B (see diagram)[2].
  • Connect the cable labeled P1 SIO to the SIO PCB at P1[3].
  • Connect the RJ-45 cable [4] to Ethernet to USB adapter [5] (P/N 33-0636).  Connect the USB connector end to the Maincon PCB J8 top port (see diagram). Add a ferrite filter 64-1252 to the USB adapter.
  • Mount the 24VDC Power Supply[11] to the left side of the control cabinet and plug into connector labled 24V PS on cable 33-8561C. Connect cable 33-1910A[10] to the 24VDC Power Supply[11] and plug into P3 on the PSUP PCB.
Note: If the machine has a Regen Vector Drive, unplug cable 33-0634 FILTER OV TO IOPCB P1 from P1 SIO and plug it into the connector FILTER OV FAULT. If the machine does not have a Regen Vector Drive, do not plug anything into the connector FILTER OV FAULT.
SKBIF to Remote Jog Handle
  • Connect the RJ12 cable 33-8550C[6] from the Remote E-stop box to cable 33-0713 and plug into the SKIBF PCB P9.
  • Remove the jumpers JP2 and JP3 on the SKBIF from the horizontal position and replace them in the vertical position.
  • Plug the RJH-XL cable into the cradle.
Robot Electrical Box to Robot Control
  • Connect the Robot Control Signal Cables [7] P/N 33-8590A to the Robot Electrical Interface Box. Add a ferrite filter 64-1252 to the RJ-45 cable.
Robot Power
  • Connect the 230VAC Power Cable [8] P/N 33-8530 to the Robot Electrical Interface Box.
Fence Interlock
  • Connect the fence door interlock cable [9] to the electrical interface box.
RJH-XL Verification
When taking the RJH-XL off the holster, the Remote Jog icon [1] should pop up on the bottom of the screen.
Then, push the [E-STOP] on the RJH-XL and make sure the E-Stop icon [2] pops up on the screen to ensure the remote e-stop works correctly.
