Shim Check List - ST Lathes
Service Home How To Procedures Shim Kit Check List - Lathes
Recently Updated Last updated: 07/01/2021
AD0452
- Jump to Section - 1. Introduction 2. SHIM KIT CHECK LIST - ST-Series Lathes 3. ST-10/15 Tailstock | ST-10/15 Base - 93-3009 4. ST-40/45/50/55 Tailstock | ST-10/15/30/30Y Base - 93-3017/93-3019 5. ST-50/55 Core Base - 93-3021 6. ST-Series - Head/Tailstock - 93-2078 7. ST-Series - Spindle Head - 93-2078 8. ST-Series - 93-2078 - Mylar Shims 9. SHIM KIT CHECK LIST - SL-Series Lathes - 93-0378A 10. SL-Series Lathes - Head/Tailstock - 93-0378A 11. SL-Series Lathes - Spindle Head - 93-0378A 12. SL-Series Lathes - Tailstock - 93-0378A 13. SL-Series Lathes - 93-0378A Mylar Shims Back to Top
This document applies to the following kits:
  • 93-3009 - SVC SHIM KIT HORSESHOE 1.8 X 1.8 X 0.7
  • 93-3017 - SVC SHIM KIT HORSESHOE 3 X 3 X 0.8
  • 93-3019 - SVC SHIM KIT HORSESHOE 4 X 4 X 1.0
  • 93-3021 - SVC SHIM KIT HORSESHOE 4 X 4 X 1.6
  • 93-2078 - LOANER, SHIM KIT FOR ST SPINDLE & TS
  • 93-0378A - LOANER, SHIM KIT FOR SL SPINDLE & TS
93-3009 1.8 x 1.8 x 0.7 Horse Shoe Shaped Shim
Thickness Part # Quanity in kit Used
0.115 59-1777 4
0.114 59-1778 4
0.113 59-1779 4
0.112 59-1780 4
0.111 59-1781 4
0.0005 59-1836 4
93-3017 3 x 3 x 0.8 Horse Shoe Shaped Shim
0.115 59-1740
0.113 59-1742 4
0.112 59-1743 4
0.111 59-1744 4
93-3019 4 x 4 x 1.0 Horse Shoe Shaped Shim
0.115 59-1752 4
0.114 15-1751 4
0.113 59-1749 4
0.112 59-1748 4
0.111 59-1747 4
93-3021 4 x 4 x 1.6 Horse Shoe Shaped Shim
0.115 59-1770 4
0.114 59-1771 4
0.113 59-1772 4
0.112 59-1773 4
0.111 59-1774 4
93-2078 - Nominal 0.2300 (1 Slot)
0.2240 20-1967 4
0.2245 20-1968 4
0.2250 20-1969 4
0.2255 20-1970 4
0.2260 20-1971 4
0.2265 20-1972 4
0.2270 20-1973 4
0.2275 20-1974 4
0.2280 20-1975 4
0.2285 20-1976 4
0.2290 20-1977 4
0.2295 20-1978 4
0.2300 20-1966 4
0.2305 20-1979 4
0.2310 20-1980 4
0.2315 20-1981 4
0.2320 20-1982 4
0.2325 20-1983 4
0.2330 20-1984 4
0.2335 20-1985 4
0.2340 20-1986 4
0.2345 20-1987 4
0.2350 20-1988 4
0.2355 20-1989 4
0.2360 20-1990 4
20-0201 - Shim - Spindle Head - Nominal 0.229 (5 Slot)
0.225 20-5415 2
0.227 20-5414 2
0.229 20-0201 2
0.231 20-0211 2
0.233 20-5413 2
0.235 20-5412 2
Mylar Shims
0.0005 59-1361 (1-SLOT) 12
0.001 59-1360 (1-SLOT) 12
0.0005 59-1206 (5-SLOT) 12
0.001 59-1207 (5-SLOT) 12
20-8812A - Shim - Head/Tailstock - Nominal 0.2300 (3 Slot)
0.2200 20-5493 2
0.2220 20-5492 2
0.2240 20-5491 2
0.2260 20-5490 2
0.2280 20-5789 2
0.2300 20-8812A 2
0.2320 20-5488 2
0.2340 20-5487 2
0.2360 20-5486 2
20-0201 - Shim - Spindle Head - Nominal 0.2290 (5 Slot)
0.225 20-5415 2
0.227 20-5414 2
0.229 20-0201 2
0.231 20-0211 2
0.233 20-5413 2
0.235 20-5412 2
20-6460A - Shim - Tailstock - Coarse - Nominal (3 Slot)
0.1040 20-6460A 2
Mylar Shims
0.0005 59-1191 (3-SLOT) 12
0.001 59-1192 (3-SLOT) 12
RECORD WHICH SHIMS WERE REMOVED FROM THE KIT IN THE USED COLUMN.
RETURN THE CHECK LIST WITH THE SHIM KIT.
RETURN THE ORIGINAL SHIMS IN THE CRATE.
