      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
ST-45/L - Coolant Collector Cover Panel - Installation - AD0683
Service Home How To Procedures ST-45/L - Coolant Collector Cover Panel - Installation - AD0683
Recently Updated Last updated: 06/09/2023
AD0683
- Jump to Section - 1. Introduction 2. Installation Back to Top
This procedure will show you how to install a cover panel over the opening for the coolant collector option on ST-45/L machines.
Machine Requirements:
  • Manufactured after 11/15/2016
  • ST-45/L Non-Reboot
Applies to the Following Service Kits:
  • 93-3812 CLNT COLLECTOR HOLE PANEL KIT ST-45
Tool Requirenments:
  • 13/64" drill bit
The machines will not have the necessary holes, use the template below:
On the coolant collector opening side of the machine, press the cover panel [1] against the machine covering the coolant collector opening.
To center the cover panel [1] with the opening, measure dimension [A] from the bottom edge of the enclosure panel to the bottom edge of the cover [1]. Measure dimension [B] from the side edge of the enclosure panel to the side edge of the cover [1].
  • A - 7.00" (17.78 cm).
  • B - 4.20" (10.67 cm).
Mark the hole location on the enclosure panel using the cover panel [1] as a template.
Drill the (x6) 13/64" holes into the enclosure panel.
Align the cover plate [1] with holes around the coolant collector opening.
Bolt the cover plate [1] using self-tapping screws over the coolant collector opening.
