MCD Relay PCB - Replacement - AD0424
Service Home How To Procedures Alarm Search: 9959 MCD Relay PCB - Replacement - AD0424
Recently Updated Last updated: 06/08/2022
AD0424
- Jump to Section - 1. Electrical Safety 2. MCD Relay PCB - Replacement (1 step) Back to Top
Electrical Safety
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
This procedure shows you how to replace the MCD Relay PCB.
Note: This PCB is also used to control a chain style SMTC, the steady rest, and the APL. In this procedure we will refer to this PCB as MCD Relay PCB.
This procedure applies to these parts:
  • P/N 93-32-3087C: SVC KIT SMTC MCODE RELAY TRIAC
[POWER OFF] the machine.
Put an identification label on each cable that is attached to the MCD Relay PCB. This makes the installation easier. Disconnect these cables.
Mark and remove all the cables from the
Remove the MCD Relay PCB from the hinge door.
Install the MCD Relay PCB [1].
Use your identification labels to connect the cables.
