    2. Español - México
    3. 한국어
    4. Українська
    2. Español - México
    3. 한국어
    4. Українська
VMC HSK-A63 Spindle - Replacement - AD0541
Service Home How To Procedures VMC HSK-A63 Spindle - Replacement - AD0541
8.1 HSK-A63 Spindle - Replacement
Recently Updated Last updated: 03/08/2021
VMC - HSK-A63 Spindle - Replacement
AD0541
This procedure tells you how to replace the HSK-A63 Spindle.
Note: If you install a new spindle, install new spindle shims when you do the VMC - SPINDLE - SPINDLE SWEEP procedure.
Note: If you install the same spindle that you remove, record the location of the spindle shims. Install the spindle shims in the same location and then do the VMC - SPINDLE - SPINDLE SWEEP procedure.
Tools Required:
  • White lithium grease
Applicable Kits:
  • 93-30-12369: SPINDLE HSK-A63 INLN 15K PIN DRV VMC SVC
  • 93-30-14458: SPINDLE HSKA63 INLIN 18K PIN DRV VMC SVC
Removal
Remove the front air scraper [1].
Record the location of the spindle lubrication fitting.
Disconnect the spindle lubrication tube.
Remove the 90° spindle lubrication fitting [2].
Install a 1/8" NPT plug [3] into the lubrication port. Install the plug [3] flush or below flush with the surface of the spindle.
Loosen the (4) screws [1] that attach the motor to the mounting plate. Do not remove the screws.
Loosen the (6) spindle screws [2] approximately (2) turns.
Install the protective cap [3] over the spindle nose.
Caution: The protective cap is necessary. It prevents damage to the spindle when it touches the table in the next step.
Jog the z-axis in the negative (-) direction until the spindle touches the table. If the spindle does not touch the table, put a wooden or aluminium block under the spindle.
Remove the (6) spindle screws [2].
Jog the z-axis in the positive (+) direction until the spindle is fully out of the spindle head.
Remove the shims [4].
Jog the z-axis in the positive (+) direction to the top of travel.
Clean and stone the spindle flange [1] and the spindle head surface [2] where the spindle flange will touch.
Caution: The motor shaft may become misaligned if spindle installation is done incorrectly.
Before installing the spindle loosen the motor mounting bolts at least a half of an inch.
If the pins are misaligned with the coupler, the motor will visibly lift instead of transmitting all of the axis thrust force into the motor shaft.
Apply a thin layer of lithium grease to these parts:
  • transfer tube [1]
  • (2) transfer tube o-rings [2]
  • pin-coupler bushings [3]
  • spindle coupler pins [5]
Install the transfer tube [1].
Turn the spindle until the lubrication port [4] aligns approximately with the position recorded when you removed the spindle.
Visually align the bushings [6] to the pins [5] on the motor coupler.
Caution: An incorrectly aligned coupler can cause damage to the bearings.
Slowly jog the z-axis in the negative (-) direction over the spindle.
While you jog the z-axis, use your hand to turn the spindle. If you feel a change in tension, stop immediately. Align the coupler pins to the bushings again.
When the spindle is fully into the spindle housing, do these steps:
  • Turn the spindle to align it with the tapped holes in the casting.
  • Install the (6) spindle screws [7].
  • Torque the crews. Refer to  HAAS FASTENER TORQUE SPECIFICATIONS. Use the value for iron.
Remove the 1/8" NPT plug [1] from the lubrication port.
Install the 90° spindle lubrication fitting [2].
Install the front air scraper [3].
Connect the spindle lubrication tube.
Perform the VMC - Spindle - Spindle Sweep procedure.
Operate the spindle at 500 RPM for 20 seconds. Stop the spindle. This aligns the motor to the spindle.
Torque the (4) screws tat attach the motor to the mounting plate. Refer to Haas Fastener Torque Specifications. The TRP can be iron or aluminium. Use the correct value for iron or aluminium.
Note: Do not add oil to the spindle casting.
  • Adjust the Push Out: Refer to HSK-A63 - Spindle Drawbar - Push Out
  • Set Z-Axis Tool Change Offset: Refer to SIDE-MOUNT TOOL CHANGER - Z-AXIS TOOL CHANGE OFFSET - NGC
  • Set Spindle Orientation: Refer to Side-Mount Tool Changer - HSK - Spindle Orentation Offset - NGC
  • Run the spindle break-in program: SPINDLE - BREAK-IN PROGRAMS - LATHE AND MILL
