Find A Dealer
    8. Español - Méjico
    9. Português
    10. Český
    11. Dansk
    12. Magyar
    14. Русский
    15. Svenska
    16. Slovenščina
    17. 한국어
    18. Slovenský
    19. 日本語
    20. Suomi
    21. Norsk
    22. Ελληνικά
    23. 中文
    24. Română
    25. Hrvatski
    26. الإنجليزية
    27. български
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
    • Product Image Automation
      Automation
      Automation View All
      • Automation
      • 5% off + saving on Automation
      • VF-2SS
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • 3D Sensor Kit, Inch, CT40
      • 3D Sensor Kit, Metric, SK40/DIN
      • 3D Sensor Kit, Metric, BT40
      • 3D Sensor Kit, Inch, HSK63A
      • 3D Sensor Kit, Metric, HSK63A
      • 3D Sensor, Inch
      • 3D Sensor, Metric
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
Find A Dealer
    8. Español - Méjico
    9. Português
    10. Český
    11. Dansk
    12. Magyar
    14. Русский
    15. Svenska
    16. Slovenščina
    17. 한국어
    18. Slovenský
    19. 日本語
    20. Suomi
    21. Norsk
    22. Ελληνικά
    23. 中文
    24. Română
    25. Hrvatski
    26. الإنجليزية
    27. български
Search
Alarm 991 - Amplifier Over Temperature (Original Release 9/18/2017)
Service Home Service Updates Alarm 991 - Amplifier Over Temperature (Original Release 9/18/2017)
June 12, 2018 Alarm 991 - Amplifier Over Temperature (Original Release 9/18/2017)
Problem:
Next Generation Control control machines equipped with a  60A servo amplifier [1] alarm 991 AXIS AMPLIFIER OVER TEMPERATURE can erroneously be generated.
Solution:
  • Install a ferrite filter (P/N 64-1252) to the axis motor power cables [2].
  • If the machine has the ferrite filter installed and the alarm persist replace the 60A servo amplifier with (P/N 93-32-5552F or later).
  • If the machine already has the 60A servo amplifier (P/N 32-5552F or later), check the amplifier PCB serial number.  Look through the amplifier vent slots, if the serial number starts with "NT", replace the amplifier with the 93-32-5552F or later (All 60A amplifiers with the serial number "NT" have been purged from stock).
  Also check for a real overheat condition.  Look at the servo fan for correct operation and the cutting application before changing any parts.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
