LIVE TOOLING
HAAS TESTED. HAAS PROVEN.
SEE ALL LIVE TOOLING
  2. Lathe Toolholding
  3. Live / Driven Turning Holders
OVERVIEW
Driven (Live) Toolholders
Haas live tooling options boost productivity by allowing secondary operations – such as milling, drilling, flatting, and tapping – to be performed in a single setup, on one machine. Two types of driven (live) toolholders are used on Haas machines, depending on the machine series* and turret type: BMT45/65/75 or VDI40. Both axial and radial toolholders are available.
BMT45/65/75
  • Industry-standard base-mount bolt pattern
  • Black oxide coating for corrosion resistance
  • Coolant delivery hardware included
  • Includes manufacturer’s warranty
VDI
  • Fits Haas VDI and VB (hybrid) turrets
  • Industry-standard 40 mm VDI mount
NOTE: Review the Duty Cycle Charts for peak performance.
*Older Haas turning centers, and some models sold in other regions, may be equipped with VDI or VB turrets, rather than BMT65.
Lathe Toolholder Selection Chart
BMT45
TOOLHOLDER SERIES
BMT45 12-Station
BMT45 24-Station
ST-10Y, ST-10LY, ST-15Y, and ST-15LY
BMT65
TOOLHOLDER SERIES
BMT65 12-Station
BMT65 24-Station
DS-30Y, ST-20, ST-20L, ST-20Y, ST-20LY, ST-25, ST-25L, ST-25Y, ST-25LY, ST-28, ST-28L, ST-28Y, ST-28LY, ST-30, ST-30L, ST-30Y, ST-30LY, ST-35, ST-35L, ST-35Y, and ST-35LY
BMT75
TOOLHOLDER SERIES
BMT75 12-Station
BMT75 24-Station
ST-40, ST-40Y, ST-45, and ST-45Y
VDI
TOOLHOLDER SERIES
VDI40
ST-10, ST-10L, ST-10Y, ST-10LY, ST-15, ST-15L, ST-15Y, ST-15LY, ST-20, ST-20L, ST-25, ST-25Y, ST-28, ST-28L, ST-30, ST-30L, ST-35, ST-40, ST-40L, ST-45, and ST-45L
VB HYBRID
TOOLHOLDER SERIES
BOT10 VDI40
ST-10, ST-10L, ST-10Y, ST-10LY, ST-15, ST-15L, ST-15Y, and ST-15LY
BOT20 VDI40
ST-20, ST-20Y, ST-25, ST-25Y, ST-30, ST-30Y, ST-35, and ST-35Y
BOT40 VDI40
VB HYBRID
TOOLHOLDER SERIES
BOT24 VDI40
DS-30SS, DS-30SSY, ST-20SS, ST-20SSY, ST-30SS, and ST-30SSY
Live Tool Duty Cycles
BMT45/65 & VDI40 Live Tool Duty Cycles
The maximum rpm is 6,000 rpm for 2 minutes and then an 8-minute cool down.
You can run a reduced rpm at 4,000 rpm at no time limit
*Parameters apply to BMT45, BMT65 and VDI40 ER32 holders
For longer periods, here are some direct contributing factors to the heat cycle:
  • Material hardness
  • Material machinability
  • Coolant on vs. coolant off
  • Coolant condition- lean or rich or dirty
  • Chip load (SFM, DOC, and stepover)
  • Cutting tool coating and recommended run parameters (cutting tool technologies)
Many times, longer cycles on a turning center are for 3D contouring or engraving. In these cases, we recommend high-speed live tool holders. This will also take the stress off the components linked to the mill drive kinematics of the machine tool if they stay under max limits.
Customers can also split the operation over more than one live tool if they have available stations on the turret. They can also check the temp of the holder during the first few parts to make sure the temp is stabilized. The max operating temp is 140º Fahrenheit.
BMT75 Live Tool Duty Cycles
The maximum rpm is 4,000 rpm for 2 minutes and then an 8-minute cool down.
You can run a reduced rpm for at 3,000 rpm at no time limit
*Parameters apply to BMT75 live toolholders
  • Material hardness
  • Coolant on vs coolant off
  • Coolant condition - lean, rich, or dirty
VIDEOS
BMT65 Live Toolholding
4 4 4 4 4 4 items
BMT45 Live Toolholding
4 4 4 4 4 4 items
VDI40 Live Toolholding
8 8 8 8 8 8 items
BMT75 Live Toolholding
4 4 4 4 4 4 items
