      • Spingibarra Haas 12
  2. Serraggio dei pezzi fresatrice
  3. Vise Kits
  4. Confezione da 4, morsa fissa a stazione singola da 100 mm (4"), apertura da 165 mm (6,5"), stile a flangia, Serraggio dei pezzi Haas di Kurt
Solo Europa
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
N. pezzo: 08-1088
HKDX4M KIT, PACK OF 4
Prezzo: 57498.95 ( / unità)
Prezzo: 17111.95 ( / unità)
Prezzo: 2299.95 ( / unità)
Prezzo: 10349.95 ( / unità)
Prezzo: 24149.95 ( / unità)
MULTI-VISE SETUPS MADE EASY
______________________________________________
Use this 4-pack of Haas Workholding by Kurt 4" (100mm) single-station fixed-jaw vises to create multi-vise setups on a single machine, or to ensure mutliple machines have identical workholding for part consistency and job flexibility. These are the same high-quality DX® Series Kurt vises we all know and love – branded specifically for Haas.
These vises are perfect for tooling up the Haas VF-2YT Pallet Pool, allowing you to set up each pallet with multiple vises for high-volume production. Each pallet’s bolt-pattern allows you to mount all 4 vises side by side, with equal spacing – no need for sub-plates, toe clamps, or custom hold-downs.
These flange-style vises have a 6.5" (165mm) maximum opening, and feature cast-in stationary jaws for less deflection and more stability during clamping. The proprietary AngLock® design ensures alignment of the moving jaw, and reduces jaw lift for superior performance. The bolt-on jaws are easily changed or reversed, and machinable steel and aluminum soft jaws are available.
  • Clamp Force Graph
  • KURT LIFETIME WARRANTY
HAI PULITO LA MORSA DI RECENTE?
Mantieni la morsa in funzione senza intoppi! Scopri come pulire e mantenere la morsa.
Impianto(i) per la vendita e-commerce 2000 (HAE)
Tipo Kit singolo
Tipo di morsa Manuale
Tipo di morsa Griffa fissa
Numero di stazioni 1
[JW] Ampiezza ganascia 4,0 pollici\100,0 mm
[VO] Apertura morsa 6,5 pollici \ 165,0 mm
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
08-1088
