      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
DT-3 Install Guide
PRE-INSTALLATION [GUIDE]
DT-3 Install Guide
    CNY ONLY
CNC Drill/Tap Center with 36" x 16" x 15.5" travels
  • 30 Taper
  • 3 Axis
  • 10k RPM
  • 20+1 Tool Capacity
  • STEP-BY-STEP GUIDE
  • Layout Drawing
  • Lifting Instructions
  • Rotary Fit
  • Additional Resources
Pre-Installation Checklist
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. The standard 6" (150 mm) concrete floor in industrial buildings is usually sufficient. However, Large-Frame machines may require a 12" (300 mm) concrete foundation. Refer to these specifications:
  • Continuous slab
☑ Anchoring
This machine requires an anchoring kit. Click here to view anchoring kits for your machine
☑ Machine Placement
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF)
Read these instructions in their entirety before attempting to lift the machine.
WARNING:
IT IS IMPERATIVE THAT PREPARATION AND LIFTING OF THE MACHINE BE PERFORMED BY PROFESSIONAL RIGGERS. THESE INSTRUCTIONS ARE FOR REFERENCE PURPOSES ONLY.
IMPORTANT: Most – but not all* – Haas machines may be lifted by overhead crane for positioning and installation. Depending on the model, your new Haas machine may have built-in lifting provisions, or may require a lifting kit, available through your local Haas Factory Outlet (HFO), that includes required lifting brackets and hardware.
Refer to the lifting placard on the rear of the machine to locate all critical lifting points.
Specialized equipment is necessary to ensure that the machine is secure and level during lifting. When lifting the machine, slowly lift until all chains are taut, then lift the machine, making sure it stays balanced. Remove lifting brackets and hardware, if installed, before machine operation, unless otherwise noted. It is the customer’s responsibility to supply all chains and spreader bars required to properly lift the machine. Contact your local HFO for more information. Retain any supplied lifting brackets and hardware, and store them in a safe place for future use. Use only Haas-supplied lifting hardware, if required.
Refer to the lifting placard on the rear of the machine for model-specific lifting information. Attach the lifting bracket, if required, and chains as shown. Make sure that the chains do not contact the sheet metal enclosure or electrical cables. Note the use of spreader bars and lumber. Haas Automation, Inc., does not provide spreader bars or lumber.
*GR, GM, TL, CM, and CL models are not suitable for overhead lifting. They must be lifted by forklift.
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 10000 rpm 10000 rpm
Spindle Power 15.0 hp 11.2 kW
Domestic Pallet 100.0 in x 91.5 in x 100.5 in 254 cm x 232 cm x 255 cm
Weight 5860 lb 5860 lb
Optional Spindles
SPINDLE SPINDLE DRIVE PEAK (HP/KW) PEAK TORQUE (ft-lb/Nm) INPUT AC VOLTAGE FULL LOAD AMPS
12,000-rpm 30T Spindle Inline Direct-Drive 15/11.2 46/62
220 (3 Phase)
440* (3 Phase)
40
20
15,000-rpm 30T Spindle Inline Direct-Drive 15/11.2 46/62
220 (3 Phase)
440* (3 Phase)
40
20
20,000-rpm 30T Spindle Inline Direct-Drive 15/11.2 46/62
220 (3 Phase)
440* (3 Phase)
40
20
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine’s electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1 ,and CM-1.
Ground
Three-Phase Power
  • For Mini Mill Series machines, some options, such as Through-Spindle Coolant, require three-phase power.
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
Rotary Fit Chart
HA2TS DT-3 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HA5C DT-3 POSITIVE FIT
HA5C2 DT-3 POSITIVE FIT
HA5C3 DT-3 POSITIVE FIT
HA5C4 DT-3 POSITIVE FIT
HA5CS DT-3 POSITIVE FIT
HRC160 DT-3 POSITIVE FIT
HRC210 DT-3 POSITIVE FIT
HRT160 DT-3 POSITIVE FIT
HRT160-2 DT-3 POSITIVE FIT
HRT160SP DT-3 POSITIVE FIT
HRT160SS DT-3 POSITIVE FIT
HRT210 DT-3 POSITIVE FIT
HRT210-2 DT-3 POSITIVE FIT
HRT210SP DT-3 POSITIVE FIT
HRTA5 DT-3 POSITIVE FIT
HRTA6 DT-3 POSITIVE FIT
T5C DT-3 POSITIVE FIT
TRT100 DT-3 POSITIVE FIT
TRT70 DT-3 POSITIVE FIT
HRT210HT DT-3 POSITIVE FIT
HRT100 DT-3 POSITIVE FIT
TH240 DT-3 POSITIVE FIT
HRT210SS DT-3 POSITIVE FIT
HA5C2-T DT-3 POSITIVE FIT
HA5C-T DT-3 POSITIVE FIT
HA5C3-T DT-3 POSITIVE FIT
HA5C4-T DT-3 POSITIVE FIT
HRT200HS DT-3 POSITIVE FIT
HQDA5 DT-3 POSITIVE FIT
* If a rotary product is not listed, it is does not have a compatible fit with this mill.
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
