DT/DM - Installation
Service Home How To Procedures DT/DM - Installation
3.1 DT/DM - Installation
Recently Updated Last updated: 01/21/2025
This procedure tells you how to install a DM-1/2/3, DT-1/2/3.
Tools Required:
  • 3/4" Socket
  • 5/32", 1/4", 3/8" Hex Bit Sockets
  • Ratchet
  • 3/4", 1.5" Wrench
  • Tape Measure
  • .0005" or 1 micron Test Indicator and Magnetic Base
  • T-2181 SERVICE TOOL, LEVELING TOOL or Precision Machinist Level, 0.0005" Division
Leveling Screws Hardware
Note: The washers [1] and nuts [2] are installed during shipping and should be saved for installation and not be discarded.
Note: The washer orientation [3] is important.  The conical part of the washer should be against the casting,  see illustration.
Remove Rust Inhibitor
For ease of removal, first use a plastic scraper to remove most of the rust inhibitor and then use either a heavy duty citrus cleaner or Simple Green to spray all the way covers and other non-painted surfaces that have been coated with rust inhibitor. Let it soak for a few minutes before removing it using a shop towel. It is recommended to apply mineral spirit or WD-40 to all exposed metal surfaces for rust proofing.
 Important: Do not use scotch-brite or metal scrapers, these will scratch the way covers. Furthermore, to avoid any contamination of the way cover seals with the sticky residue. Do not move any of the axes until all the rust inhibitor has been removed.
Note: The product is not hazardous and can typically be disposed of similarly to used oil.
: https://vimeo.com/haasautomation/review/171129636/7c2a5127f9
Air Connection
Connect the air supply at the lube panel.
 Note: For air requirements refer to the decal that is located on the lube cabinet door.
Follow the Air Gun and Hose Installation procedure to install or replace the Air Gun.
 Note: Some installation kits will come with a spare air gun assembly.
Electrical Installation
Danger: WORKING WITH ELECTRICAL SERVICES REQUIRED FOR A CNC ARE EXTREMELY HAZARDOUS. ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO CONNECTING THE LINE WIRES TO CNC. HOWEVER, IF THIS NOT THE CASE OR ARE NOT SURE HOW TO DO THIS, CHECK WITH APPROPIATE PERSONNEL OR OBTAIN THE NECESSARY HELP BEFORE CONTINUING. ALWAYS CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR TO MAKE SURE POWER HAS BEEN DISCONNECTED.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
Shipping Brackets Removal
DT Machines:
Remove the shoulder bolt, shipping bracket [1] and cam [2] on the front door handle.
DM Machines:
Remove the shoulder bolt [3] holding the operator door in place. Access these bolts through the operator door opening on all machines.
Remove the shoulder bolt [4] holding the control pendant in place.
Press [POWER ON] and follow the instructions indicated on the screen.
Press the [HAND JOG] and [Z+] buttons. Jog the Z-axis upward.
Remove the spindle shipping bracket [5].
Machine Leveling
Zero return each axis one at a time or press [POWER UP]. Go through the leveling process.
Repeat these steps to achieve correct machine level.
Set the machine height using the four corner leveling bolts [1 ,2, 3, 4] to 3" +/- .5" (75 mm +/- 10 mm) above the floor. Turn each screw so they have equal tension.
Jog the X-axis and Y-axis to the middle of their travel, centering the table.
 Note: The image shows the layout of the DM-2, but the same process applies to all DM, DT machines with four leveling bolts. If your machine has six or more leveling bolts, please see:
VMC Leveling
Clean the table surface and leveling tool (T-2181) and check the calibration of the leveling tool before proceeding.
Position the level at the center of the table, parallel to the X-axis. Use a t-slot for alignment.
Note the position of the bubble.
Reposition the level by turning it 180 degrees. The bubble should display the same reading as previously.
If the readings are different by more than one division, return the level to Haas for adjustment and do not use it to level the machine.
Adjust corner leveling bolts [1, 2] or [3, 4] until the bubble parallel with the Y-axis is centered.
This levels the machine front to back.
Always raise the lower side of the machine to maintain clearance for the coolant tank (if equipped) and adjust the two leveling bolts on that side an equal amount.
Adjust corner leveling bolts [1, 3] or [2, 4] until the bubble parallel to the X-axis is centered.
This levels the machine left to right.
Again, raise the lower side of the machine and adjust the two leveling bolts on that side an equal amount.
Keep the level in the same position and jog the Y-axis to bring the table to the front of the machine.
Jog the Y-axis across its full travel, stopping at the column. Look to see which rear corner of the machine is lowest, as shown by the leveling tool.
Raise the lowest rear corner by adjusting corner leveling bolt [3] or [4] until the bubble is centered on the level.
Jog the Y-axis back across its full travel, bringing the table to the front of the machine. Look to see which front corner is lowest, as shown by the level.
Raise the lowest front corner by adjusting corner leveling bolt [1] or [2] until the bubble is centered on the level.
Repeat steps 6 and 7, moving the table back and forth across the full travel of the Y-axis, raising the lowest corner each time.
Continue this process until the level reads zero at both ends of the Y-axis travel.
Spindle Sweep Check
Attach indicator to spindle head. Position the table and indicator to sweep a circle 10" in diameter.
Place a gauge block on the table.
Jog the spindle down and zero the indicator at Position 1.
Using a gauge block every 90 degrees, check that the difference in these measurements don't exceed 0.0005". If it does, check the machine level.
Lock the leveling bolts in place by tightening the locking nut while holding the leveling bolt. Ensure that the leveling bolts do not move during this process.
For a more indepth guide on how to perform this procedure, please see:
VMC Spindle Sweep
Lubrication Verification
Run the spindle run-in program.
 Note: For 10K spindles and above use a balanced tool holder
Examine the sight glass, make sure the correct number of drops are fall through the sight glass.
Examine the fittings [1,2] on top of the oil pump tank.
The oil collects on top of the oil pump tank [3] either behind or in front of the sight glass bracket, underneath the leaking fitting.
Tighten any leaking fittings.
Go to the Maintenance tab.
Press [F2] to cycle an axis lubrication test.
Inspect the gauge on the lubrication system.  Make sure it holds pressure.
Hose Installation
Connect the Coolant Pump and the Through Spindle Coolant (TSC) Pump (if equipped).
Attach the blue coolant hose from the filter inlet to the Coolant Pump outlet.
Plug in the Coolant Pump to the Low Pressure Coolant plug.
Attach the TSC Pump to the small purple coolant hose.
Plug in the TSC Pump to the High Pressure Coolant plug.
Plug in the Coolant Level Sensor and other related sensors to the corresponding plugs.
Option Installation Guides
Verify and test that all the options have been properly installed.
Remote Jog Handle (RJH-Touch) - Installation
Wi-Fi Camera Option Installation
VMC Convenience Package
Auxilary Coolant Filter
CABCOOL installation
Pulsejet Installation
HAAS Oil Skimmer
Table work light
Tool Air Blast
Auto Air Gun
Mini Conveyor
Final Testing
Spindle Operation
Run the Spindle Run-In program O09221.
In the case of an unusual spindle noise, run a vibration test. For a guide on how to perform a spindle vibration test please see:
Vibration Analysis - Ethernet Interface
Vibration Analysis - RS-232 Interface
Coolant Operation
Fill the coolant tank with the necessary gallons of coolant in order to fill the tank.
Connect the coolant pump.
Run coolant by pressing  [COOLANT] on control pendant.
If machine comes equipped with TSC, insert a TSC toolholder in the spindle [1].
Press [AUX CLNT] to start the TSC.
Correct operation is as follows:
  1. Coolant flows correctly from the TSC tool holder.
  2. A few drops flow from the vacuum-generator hose [2].
Press [RESET].
Through-Tool Air Blast (TAB)
If machine comes equipped with TAB, operate this code in MDI mode:
M73;
G04 P5.;
M74;
G04 P3.;
M99;
M73 starts the TAB. M74 stops the TAB.
Manually operate the TAB:
Press [AUX CLNT]. Press the [RIGHT] cursor arrow.
The tool air blast starts.
Press [AUX CLNT].
The tool air blast stops.
Chip Auger
Press [CHIP FWD] and [CHIP REV] on the control.
For an in depth guide on Chip Auger installation on DM and DT series machines, please see:
Chip Auger Installation
Door Interlock
Press [MDI]. Type in S500 M3; Press [ENTER].
Make sure the machine IS NOT in SETUP MODE by Checking the KEY SWITCH on the side of the pendant
With the door open, press [CYCLE START]. The machine should say to close the door and press [CYCLE START].
With the door closed, press [CYCLE START]. The interlock pin should extend and the spindle starts rotating.
 IMPORTANT: With the spindle rotates, test the door locks by trying to open the door. The spindle should not stop rotating.
Test Key Switches
Insert the Setup/Run Lock Key (#2007) to the lower key slot and turn to the unlocked position.
Verify that the key can only be removed from the locked position.
Insert the Memory Lock Key (#2341) to the upper key slot and turn to the locked position.
Verify that the key can be removed from either position.
With the Memory Lock Key in the locked position, verify that changes cannot be made to the settings or programs.
Auto Window Installation
If machine came equipped with an auto window, remove the enclosure cover above the auto window.
Bolt the bottom bracket [1] to the enclosure above the window.
Loosen the sensor clamp [2] on the bottom of the air cylinder.  Insert sensor [3] in between clamp and piston rod. Before tightening the sensor clamp, refer to the Auto Window - Troubleshooting Guide for sensor location.
Remove the fitting plugs on the top and bottom of the air cylinder.  Connect the yellow airline [4] to the bottom hose fitting and the grey airline [5] to the top hose fitting.
Reinstall enclosure cover.
To test the auto window, operate this code in MDI mode:
M59 P151;
G04 P5.;
M69 P151;
G04 P5.;
M99;
Rotary Installation
If your machine came with a HRT or TRT rotary table please see the following link for installation instructions:
Rotary Installation
WIPS Calibration
If your machine includes the WIPS option, please see the following link for instructions on the calibration procedure:
WIPS Calibration NGC
Wifi Camera Operation
If the machine came with the Wifi Camera option, please see the following link for installation instructions:
Wi-fi Camera Installation
Mill Maintenance Schedule
Keep your Haas machines running at peak performance while avoiding unplanned downtime. A maintenance program allows you to manage your schedule rather than getting caught with untimely surprises. Please see the link below for recommended maintenance intervals.
