1 - HL50E - Introduction
HL50E - Operator's/Service Manual
  • 0 - HL50E - Table of Contents
  • 1 - HL50E - Introduction
  • 2 - HL50E - Safety
  • 3 - HL50E - Installation
  • 4 - HL50E - Operation
  • 5 - HL50E - Maintenance
  • 6 - HL50E - Troubleshooting
  • 1.1 SERVICE DISCLAIMER
  • 1.2 INTRODUCTION
  • 1.3 SPECIFICATIONS
Disclaimer
Only a certified technician is allowed to repair this machine.
All information provided for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only services and repairs provided by authorized Haas Factory Outlet technician are guaranteed.
Only an authorized Haas Factory Outlet distributor should service or repair a Haas machine that is protected by the original factory warranty. Servicing by any other party voids the warranty.
1.2 INTRODUCTION
This service manual will show you how to install, operate and maintain the HL50E Laser Marking Machine.
1.3 SPECIFICATIONS
HL50E Components
The HL50E Fiber Laser Marking Machine consists of three main components: an energy source, a laser medium, and an optical resonator.
This section provides detailed specifications for the HL50E.
HL50E Specifications
LASER S.A.E. METRIC
Module Han's Laser Han's Laser
Power 50.0 W 50.0 W
Power Stability (8h) <±1% rms <±1% rms
Power Requirement 110 VAC 220 VAC
Output Power 10% to 100% 10% to 100%
Output Frequency 20 kHz to 100 kHz 20 kHz to 100 kHz
Beam Quality M²< 1.3 M² < 1.3
Wavelength 1064nm (Infrared) 1064nm (Infrared)
Repeatability ±0.0001 in ±0.003 mm
Focus Spot Diameter <0.0004 in <0.01 mm
Minimum Line Width 0.0004 in 0.01 mm
Marking Range 4.3 in x 4.3 in (F160 lens) 110 mm x 110 mm (F160 lens)
Marking Depth 0.047 in 1.2 mm
Marking Speed 800 std. characters/sec 800 std. characters/sec
Cooling Air Cooled Air Cooled
Fume Extractor S.A.E. METRIC
Input Power 310.0 W 310.0 W
Filter Efficiency 11.8 µin, 99.97% 0.3 µm, 99.97%
System Flow Rate 21895 ft³/hr 620 m³/hr
Noise <60db <60db
DIMENSIONS S.A.E. METRIC
Overall Length (L) 43.7 in 1110 mm
Overall Width (W) 28.9 in 735 mm
Overall Height (H) 64.6 in 1640 mm
Enclosure Length (A) 39.4 in 1000 mm
Enclosure Width (B) 27.4 in 695 mm
Enclosure Height (C) 33.5 in 850 mm
Fixture Plate 17.7 in x 13.8 in 50 mm x 350 mm
Fume Extractor 21.7 in x 16.3 in x 36.2 in 550 mm x 415 mm x 920 mm
GENERAL S.A.E. METRIC
Country of Origin China China
Gross Weight 426 lbs 193 kg
Warranty 12-month 12-month
Window Specification S.A.E. METRIC
