6 - Haas Surface Grinder - Maintenance
Haas Surface Grinder - Operator's/ Service Manual
  • 0 - Haas Surface Grinder - Table of Contents
  • 1 - Haas Surface Grinder - Introduction
  • 2 - Haas Surface Grinder - Legal Information
  • 3 - Haas Surface Grinder - Safety
  • 4 - Haas Surface Grinder - Installation
  • 5 - Haas Surface Grinder - Operation
  • 6 - Haas Surface Grinder - Maintenance
  • 7 - Haas Surface Grinder - Troubleshooting
  • 6.1 Service Parts List
  • 6.2 HSG - Maintenance Schedule
Service Parts List
Part Numbers Description
93-4718 AC CONTACTOR HSG-2550
93-4719 TRANSFORMER HSG-2550
93-4720 CIRCUIT BREAKER HSG-2550
93-4721 Z-AXIS PULLEY BELT HSG-2550
93-4722 Y-AXIS PULLEY BELT HSG-2550
93-4723 Z-AXIS SCREW WITH NUT HSG-2550
93-4724 Y-AXIS SCREW HSG-2550
93-4725 O-RING HYDRAULIC CYLINDER HSG-2550
93-4726 GUIDE BELT HYDRAULIC CYLINDER HSG-2550
93-4727 GLYD RING HYDRAULIC CYLINDER HSG-2550
93-4728 DUST SEAL HYDRAULIC CYLINDER HSG-2550
93-4729 HYDRAULIC CYLINDER SEAL RING HSG-2550
93-4730 DC RELAY HSG-2550
93-4731 AC RELAY HSG-2550
93-4732 MAIN POWER SWITCH HSG-2550
93-4733 POWER SUPPLY HSG-2550
93-4734 MOTOR CIRCUIT BREAKER 2.5-4A HSG-2550
93-4735 MOTOR CIRCUIT BREAKER 0.4-0.63A HSG-2550
93-4736 MOTOR CIRCUIT BREAKER 4-6.3A HSG-2550
6.1 HSG - Maintenance Schedule
Items Lubrication Interval
Inspect lubrication tank level.
ISO 68 oil for guide ways (e.g Mobil Vactra Oil No.2) Daily
Clean the filter inside the oil reservoir
ISO 68 oil for guide ways (e.g Mobil Vactra Oil No.2) Biannually
Inspect hydraulic unit level ISO 32 hydraulic oil (e.g Mobil DTE 10 Excel 32) Monthly
Inspect coolant tank level Cutting fluid Monthly
Note : New machines need to change the hydraulic oil in the hydraulic tank after the first 3 months. It is recommended to change the hydraulic oil annually after the initial change.
Daily Inspection
Item inspection Items Machine State Action / Verification
Off On
1 Lubrication tank level X   Ensure oil level is above the limit line
2 Table speed control lever position X   Set to the lowest setting
3 Grinding wheel position X   Above work piece
4 Hydraulic unit Level X   Shut off
5 Cooling unit level X   Shut off
6 Spindle motor X   Shut off
7 Grinding wheel cover X   Closed and locked
8 Electrical panel door X   Closed and locked
9 Running direction   X Clockwise
10 Warm-up   X 30 minutes before full operation
