40-Taper - TSC Ready - 300/1K PSI Install 2017 and after - VMC - NGC - AD0458
Service Home How To Procedures Alarm Search: 4.103 40-Taper - TSC Ready - 300/1K PSI Install 2017 and after - VMC - NGC - AD0458
Recently Updated Last updated: 04/28/2025
40-Taper Inline - TSC Ready - 300/1K PSI Install 2017 and After - VMC - NGC
AD0458
- Jump to Section - 1. Install Kit 2. 40-Taper Inline - TSC Ready - 300/1K PSI Install 2017 and After - VMC - NGC (3 steps) 3. TSC - 300 and 1K PSI - Test (1 step) Back to Top
Install Kit
To select the correct TSC install kit for your machine refer to: Through Spindle Coolant - Field Install Kits
  • Remove and discard the larger cover adjacent to the standard coolant pump.
  • Install the smaller cover adjacent to the standard coolant pump.
  • Install the TSC pump [E]. If necessary, remove the #8 fitting [1] and install the #6 fitting [2]. The #6 fitting [2] is for machines that have a 3/8" hose.
On the TSC-purge solenoid, find the fitting [4] that does not have a check valve. Connect the other 20' (6096 mm) 1/4" purple tube [3] to the fitting [4] and to the air cylinder on the pump.
Connect the 3/8" hose [A] to the pump.
If you did not install the 12' TSC extension cable [C]:
Discard the plug [5] for the receptacle bracket.
Install the 12' TSC extension cable [C].
Connect the 4-pin connector [1] of the cable [C] to P31 [2] on the I/O PCB.
Install the receptacle end [3] of the cable [C] to the receptacle bracket. Use the twist lock mount [4] and the screws.
Connect the power cable for the TSC coolant pump to the receptacle end [3] of the TSC extension cable [C].
Install the 13.5' vacuum-sensor cable [D] between P28 [1] on the I/O PCB and to the vacuum sensor [2] for the TSC pump.
Refer to the Next Generation Control - Option Activation procedure.
Put a TSC toolholder [1] in the spindle. Push [AUX CLNT] to start the TSC.
Correct operation is as follows:
  1. Coolant flows correctly from the TSC tool holder.
  2. A few drops flow from the vacuum-generator hose [2].
Push [RESET].
