    2. Español
    3. Français
    4. Italiano
    5. Português
    6. Český
    7. Dansk
    8. Nederlands
    9. Magyar
    10. Polski
    11. Svenska
    12. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    2. Español
    3. Français
    4. Italiano
    5. Português
    6. Český
    7. Dansk
    8. Nederlands
    9. Magyar
    10. Polski
    11. Svenska
    12. Русский
Search
Axis Grease Reservoir - SHC 007 - Metal Retrofit Kit - AD0529
Service Home How To Procedures Axis Grease Reservoir - SHC 007 - Metal Retrofit Kit - AD0529
Recently Updated Last updated: 02/11/2021
AD0529
- Jump to Section - 1. Axis-Lubrication Reservoir Assembly- Replacement (2 steps) 2. Grease Reservoir - Prime and Test (2 steps) Back to Top
PN: 93-2599A AXIS LUBE RSRVR METAL RED GREASE SRV A
Disconnect the input air hose[1] and output grease hose[2] from the plastic axis-lubrication reservoir.
Remove the plastic axis-lubrication reservoir assembly from the cabinet.
Install the metal axis-lubrication manifold into the cabinet.
Note: Use the adapter bracket [1] if the holes in the cabinet do not match the holes in the head assembly. Make sure the bracket is oriented as shown.
Install the metal reservoir with Mobil Mobilith SHC007 or Haas 93-1933A (do not substitute).
NOTE: Haas part number is 93-1933A SRVC GREASE REFILL 72CU-IN, SHC007 - 1QT
Connect the output grease hose [2] and input air hose [3].
If the machine has a Classic Haas Control, do these steps:
  • Press [PARAMETER DIAGNOSTIC] (2) times to show the diagnostics page.
  • Press [CANCEL].
  • Go to the [LUBE] tab.
  • Press [WRITE/ENTER] .
  • Press [F2] to start the Axis-Lubrication Test.
If the machine has as Next Generation Control, do these steps:
  • Press [DIAGNOSTICS].
  • Go to the [MAINTENANCE] tab.
Perform the Axis-Lubrication Test again until you no longer get axis lubrication alarms. Wait a minimum of (1) minute between Axis-Lubrication Test cycles.
Check the level of the grease in the reservoir.
If the grease lines were nearly empty, it may be necessary to refill the axis-lubrication reservoir after you purge the lines of air. Pour the grease into the reservoir: to about 1/2" (13mm) below the threads on the reservoir.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
