Sigma-1 - Axis Servo Motor Cable - Replacement
Service Home How To Procedures Sigma-1 - Axis Servo Motor Cable - Replacement
Recently Updated Last updated: 12/22/2022
Applies to machines built from: January, 1996
- Jump to Section - 1. Introduction 2. Cable Replacement (1 step) Back to Top
This procedure tells you how to replace these brushless axis cables:
  • 2-Cable set: motor power and encoder
  • 3-Cable set: motor power, encoder, and brake
Cable Replacement
Put labels on the locations of the cables you will replace.
  • The encoder cable connection location is on the processor PCB [1]
  • The power cable connection location is on the amplifier [2]
  • If you have a brake cable, the connection location is on the I/O PCB [3]
Disconnect the cables from the control cabinet and the motor. Remove the axis cable from the machine.
Fill the amphenol connectors on the motors [4] with dielectric grease.
Install the new axis cable. Route the axis cable the same as the used cable.
