  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Single Action Parts Catcher - Flat Door - Installation - ST-10/15 - AD0439
Service How To Procedures Single Action Parts Catcher - Flat Door - Installation - ST-10/15 - AD0439
Recently Updated Last updated: 01/28/2019
AD0439
- Jump to Section - 1. Machine Compatibility 2. Document Applies to these Parts 3. Single Action Parts Catcher - Installation (5 steps) Back to Top
  • ST-10/15 with a flat door
KIT P/N 93-2716A QTY: 1
Download the Parts Catcher patch file from the Haas Service Portal and install it on the machine.  Refer to: PATCH FILE LOAD UNINSTALL - NGC.
Turn off the main air supply at the lube rack.
Connect the air lines from the kit to the appropriate colored fittings on the new Pcat assembly.
Install the new parts catcher assembly using the (4) mounting bolts [1].
Route the air hoses [2] up behind the light through the hole in the top panel.
Remove the covers and route the cables through the cable chanels on top of the machine back to the lube rack [3].
Install the rotation solenoid and plug it into the PARTS CATCHER plug.
Plug the hoses into the correct color coded ports.
Fully open the operators door.
Unbolt the (4) door header bolts.
Lean the door off the machine and remove it.
Install the new door with the lower rollers on track.
Install the (4) door header bolts.
Discard the old door.
Loosen the adjustment set screw [1].
Position the chute assembly [2] to catch cut off parts.
Tighten the adjustment set screw [1].
Turn on the main air supply at the lube rack.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
