      • Fiber Laser
      • VF-4SS
ST-20/30 - Tailstock - String Encoder - Replacement - AD0227
Service Home How To Procedures Alarm Search: 9918 ST-20/30 - Tailstock - String Encoder - Replacement - AD0227
- Jump to Section - 1. Introduction (5 steps) 2. Replacement (5 steps) Back to Top
Recently Updated Last updated: 09/24/2024
AD0227
This procedure tells you how to replace the string encoder for the tailstock. The string encoder tells the control the travel distance of the tailstock.
  • 93-4385: ENCDR LINEAR STRING ASSY UNIMEASURE SRV KIT
Note : This encoder is a direct substitute for siko or microepsilon brand encoders and requires no modification.
Machine Compatibility :
  • ST-20 Built from 06/2012 (with string encoder)
  • ST-30 Built from 06/2012 (with string encoder)
Replacement
Push [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker.
Remove tailstock outer hydraulic cylinder cover [2].
Remove the hydraulic cylinder inner cover to gain access to the encoder.
Detach the encoder string from the bracket on the tailstock.
Install the new ENCODER [1].
Connect the ENCODER [1] female connector end to the male 690B cable that connects to the MAINCON PCB.
Attach the string from the new encoder [1] to the bracket [2].
Reinstall the inner and outer hydraulic cylinder covers.
Set the main circuit breaker to the ON position. Push [POWER ON].
Caution: After you extend the encoder string, make sure you do not release it. If the encoder string retracts quickly, this can cause damage to the encoder.
Classic Haas Control: Install the correct parameters for the new tailstock string encoder type. Use the Parameter Checker program. Use menu item 1. Refer to Parameter Checker Program.
