    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
Standard Coolant - Washdown Hose - Installation - VMC - AD0104
Service Home How To Procedures Standard Coolant - Washdown Hose - Installation - VMC - AD0104
3.4 Washdown Hose - Installation
Recently Updated Last updated: 06/07/2022
AD0104
Applies to machines built from: November, 2013
This procedure tells you how to install a washdown hose. The kit for the washdown hose is in the tote kit.
Mills larger than the VF-5 have a second washdown hose. To install a second washdown hose use this procedure: Supplemental Washdown Hose
These instructions apply to these machines:
  • VM-1/2 - Made after 11/13/2013
  • VF-1/2 - Made after 11/13/2013
  • VF-3/4/5 - Made after 02/20/2014
  • VF-6/7/8/9/10/11/12 - Made after 06/09/2014
  • DT-1 - Made after 06/09/2014
  • DM-1 - Made after 01/01/2015
  • MM/SMM - Made after 07/01/2015
Parts Required
58-1650A
QTY: 1
HOSE 3/8 ID 3/4 GHM 3/4 GHF 13.5FT
59-6310A
QTY: 1
WASHGUN, WASHDOWN GILMOUR 573
30-11613
QTY: 1
WASHGUN, HOLSTER AND GASK
40-1981
QTY: 3
FBHCS 1/4-20 X 1/2 LOCTITE
Tools Required
Crescent Wrench
5/32" Allen Wrench
Apply thread sealant to all threaded surfaces of the coolant fittings.
Find the cap [1] at the bottom left on the enclosure. Remove the cap [1] from the MALE ENCLOSURE FITTING [2].
 Note: Coolant can come out when you remove the cap.
Attach the WASH GUN HOLSTER and GASKET [E] to the enclosure face. Use the screws [F].
NOTE: For proper operation, make sure the wash gun gasket is properly seated. It needs to be flush at the bottom of the wash gun housing.
Attach the HOSE ASSEMBLY [C] to the MALE ENCLOSURE FITTING [2]. Attach the HOSE ASSEMBLY [C] to the WASH GUN [D].
Put the HOSE ASSEMBLY [C] in the WASH GUN HOLSTER [E].
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
