TRT70 MRZP TRAVEL KIT - Installation - AD0858
Service Home How To Procedures TRT70 MRZP TRAVEL KIT - Installation - AD0858
Recently Updated Last updated: 03/19/2025
TRT MRZP Travel Kit - Installation
AD0858
- Jump to Section - 1. Introduction (4 steps) 2. TRT70 Mounting Plate Removal (2 steps) 3. TRT70 New Mounting Plate Installation (2 steps) Back to Top
This procedure involves removing the current mounting plate and replacing it with an updated one to accommodate the extended travel range on the A-axis (tilt) of the TRT70, from +120 to -35 degrees, increased to +120 to -95 degrees.
This Procedure Applies to the Following Kit:
  • 93-3799 - MRZP TRAVEL UPDATE KIT +120/-95DEG TRT70
Loosen the two hex bolts that secure the TRT70 to the table at [1].
Using the handle [2] on top of the rotary, lift it out of the T-nuts and set the rotary aside.
Remove the two hex bolts securing the mounting plate to the TRT70. The front hex bolt is located at [1], and the rear hex bolt is located at [2].
Align the new mounting plate to the TRT 70 by using the locating pins [1] found on the bottom of the rotary.
Once aligned, reinstall the removed hex bolts to securely attach the new mounting plate to the TRT 70.
Note: Install the new mounting plate in the correct orientation as shown in [2]. This is to prevent the motor from colliding with the plate.
Use the hex bolts from the removal process to reattach the rotary to the table.
Align the rotary with the t-nuts on the table and tighten the bolts to secure the rotary's position.
