      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
UMC-350 - Rotary Waycover Service Kit - AD0740
Service Home How To Procedures UMC-350 - Rotary Waycover Service Kit
Recently Updated Last updated: 01/17/2024
AD0740
- Jump to Section - 1. Introduction 2. Removal (1 step) 3. Installation (6 steps) 4. Verification Back to Top
This procedure outlines how to replace the sheet metal and waycover parts around the rotary in a UMC-350HD to help with coolant intrusion.
The procedure applies to the following service kit:
  • 93-3942: ROTARY LEAK FIX SVC KIT UMC-350HD
Removal
Jog the y-axis to the front of the machine for best access to the parts around the rotary.
Pull back the y-axis waycover [1].
Remove the wipers [2] and rotary rear cover [3].
Remove the remaining sheet metal parts: back panel [4], lower panel [5], and front cover [6].
Install the new back panel [1], lower panel [2], and front cover [3] reusing the old hardware as shown in [4] and [5].
Attach two (2) pieces of thick foam tape [1] as shown in red onto the top of the rotary.
Attach a piece of thin foam tape [2] on the back sheet metal panel as shown in green.
Attach thin foam tape on the right [3] and left [2] sheet metal panels as shown in green.
Attach a piece of thin foam tape [2] on the new rotary rear cover so that it lines up with the piece on top of the back sheet metal panel [2].
Re-attach the y-axis waycover and apply RTV silicone where the waycover gets fastened to the front cover [6] on both sides.
Install the new rotary rear cover [1] by attaching it to the back panel on the left [2] and right [3] sides.
Attach the rotary rear cover [1] to the front cover using the old hardware on the right [4] and left [5] sides as shown.
Re-attach the y-axis waycovers.
Attach the new chip shields on the right [1] and left [2] to the rotary rear cover [3].
Attach the new side brass wipers [1] and their sheet metal covers [2] as shown.
Attach the new top brass wiper [2] and its sheet metal cover [1] as shown.
Verification
Hand jog the y-axis to verify smooth movement and no binding happens.
