Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
    • Product Image Automation
      Automation
      Automation View All
      • Automation
      • 5% off + saving on Automation
      • VF-2SS
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • 3D Sensor Kit, Inch, CT40
      • 3D Sensor Kit, Metric, SK40/DIN
      • 3D Sensor Kit, Metric, BT40
      • 3D Sensor Kit, Inch, HSK63A
      • 3D Sensor Kit, Metric, HSK63A
      • 3D Sensor, Inch
      • 3D Sensor, Metric
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
VMC - SMTC Cambox - Oil Level Inspection
Service Home How To Procedures VMC - SMTC Cambox - Oil Level Inspection
Recently Updated Last updated: 10/17/2022
- Jump to Section - 1. Introduction 2. Check the oil level (5 steps) 3. Refill the Cambox (2 steps) Back to Top
This procedure covers how to measure the oil level and fill the cambox of a side-mount tool changer (SMTC) on a vertical mill.
Vertical mill SMTC camboxes will have either a sight glass [1] or will have an oil-level plug [2]. The oil-level sight glass and the oil-level plug are in the same location on the SMTC cambox. However, the most effective way to check the oil level is with a dipstick [3].
The recommended oil level has been raised, and 4 inch (101 mm) from the top surface of the cambox is currently recommended for all vertical camboxes no matter when it was manufactured. This is higher than the sight glass and the oil level plug, so these are no longer recommended to use for checking oil level.
Important: If a cambox's oil level is not at the correct height that may not indicate that the cambox is leaking. Over time the cambox will slowly lose oil or the cambox may have been filled to lower oil level previously. Before replacing the cambox do more investigation to see if the cambox has been damaged and is leaking.
    Required parts
  • T-0144 CAMBOX OIL LEVEL DIPSTICK
Check the oil level
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker. Use an approved lock and an approved safety tag.
Using a Dipstick part 1
Remove any sheet metal necessary to access the top of the SMTC cambox and remove the muffler [1] from the top of the cambox. This can be done with a 9/16-inch wrench.
Using a Dipstick part 2
Make a mark at the point labeled [3] 4 inch (101 mm) from the reference surface [1].
The part labeled [1] will be flush with the top of the cambox. The horizontal labeled [2] should not be used as a reference.
Using a Dipstick part 3
Put the dipstick [1] into the whole at the top of the cambox till it is all the way down as shown in the picture to the left.
Pull the dipstick out and check if the oil is above or below the 4 inch (101 mm) mark made in step 2.
If the oil level is correct, no further action is required.
If the oil level is low, go to the next section.
If the cambox is overfull, do not drain the extra oil.
Using the sight glass or Oil-level plug
Warning: It is no longer recommended to use either the sight glass or oil level plug as they are lower than the recommended fill level.
Remove the carousel cover if it is blocking the sight glass or oil level plug.
Look through the carousel and find the sight glass for the cambox oil level [2], or the oil-level plug [1].
View the oil level through the sight glass [2], remove the oil-level plug [1]. If the oil level is correct, oil comes out of the oil-level hole. Install the oil-level plug.
Refill the Cambox
Use a funnel to add oil to the cambox until it is 4 inch (101 mm) from the top. Check the level again with a dipstick to verify the level is correct.
Note: Refer to Lubricant Table for Haas Machine Components for the correct oil type.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
