      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Linear Scale - Parameters - 1997
Recently Updated Last updated: 11/27/2018
Always use the Parameter Checker program to analyze the parameters.
These are the values required for all Vertical mills with linear scales installed.
Verify that they are correct.
Parameter Value
Parameter 266 bit 0 X SWITCH B LIN SCALE EN
Parameter 266 bit 1 X SWITCH B INVRT LN SCL
Parameter 266 bit 5 X NEG COMP DIR
Parameter 267 bit 0 Y SWITCH B LIN SCALE EN
Parameter 267 bit 1 Y SWITCH B INVRT LN SCALE
0 (VF-3,4,5)
1 (VF-6 andlarger)
Parameter 267 bit 5 Y NEG COMP DIR
Parameter 268 bit 0 Z SWITCH B LIN SCALE EN
Parameter 268 bit 1 Z SWITCH B INVRT LN SCALE
0 (VF-3,4,5)
1 (VF-6 andlarger)
Parameter 268 bit 5 Z NEG COMP DIR
0 (except HS 3-7 and ECs - set these mills to 1)
Parameter125 X GRID OFFSET
Must be determined for each machine
Parameter126 Y GRID OFFSET
Parameter127 Z GRID OFFSET
Parameter279 X LSC GAIN MULTIPLIER
40
Parameter280 Y LSC GAIN MULTIPLIER
40
Parameter281 Z LSC GAIN MULTIPLIER
40
Parameter285 X LSC OFFSET
400000
Parameter 286 Y LSC OFFSET
-400000
Parameter 287 Z LSC OFFSET
Sum of parameter 64 and 400000
Parameter327 X LS PER INCH
25400
Parameter 328 Y LS PER INCH
25400
Parameter 329 Z LS PER INCH
25400
Parameter 333 X LS PER REV
50000
Parameter 334 Y LS PER REV
50000
Parameter 335 Z LS PER REV
50000
Machine Accuracy Parameters
Parameter Value
Parameter 14 X DEAD ZONE 0
Parameter 28 Y DEAD ZONE
Parameter 42 Z DEAD ZONE
Parameter 140 Z FRICTION COMPENSATION
Parameter 145 X ACCEL FEED FORWARD
-500000
Parameter 146 Y ACCEL FEED FORWARD
500000
Parameter 147 Z ACCEL FEED FORWARD
-500000
