  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Control Software Errors Can Cause Display Malfunctions
Service Service Updates Control Software Errors Can Cause Display Malfunctions
October 05, 2016 Original Release: 06-27-2014
Recently Updated Last updated: 2016-10-05T00:00:00.000-07:00
Updated 10-05-2016: Clarified the Permanent Solution statements.
Update: Added a permanent solution for all issues.
Issue 1
 A user creates a program with the number O80000, or edits the O80000 program in memory. This causes the display to change to a black screen with blue letters when the user selects the IPS POCKET MILLING tab and then selects the IRREGULAR tab (project # 46963.001).
Cause: Software error.
Permanent Solution: Install the latest version of software available. As of the date of this Service Alert, the current Mill software version is M18.21C and current Lathe software version is L11.17C.
 Note: Do not replace any parts to repair this issue.
Issue 2
Too many consecutive DPRNT statements causes the display to change to a black screen with blue letters (project # 46763.001).
Issue 3
The screen stays dark after you try to get out of power-save mode (project # 47065.001).
Issue 4
The machine display shows boxes and lines that are out-of-place (project # 47058.001).
  • Intermittently occurs when you press [RESET] or [POWER UP/RESTART] while in [MEM] or [EDIT] mode (with or without running a program)
  • Intermittently occurs when you change screens while in MEM or EDIT mode (with or without running a program)
One or more of these alarms shows:
  • 101 MOCON COMM. FAILURE
  • 491 KEYBOARD INTERFACE COMMUNICATION
  • 825 MAIN CONTROL INTERFACE FAULT
  • 967 SKBIF COMMUNICATION FAULT
Issue 5
You get one or more of these symptoms: (project # 47058.001)
  • The control runs slow.
  • Random characters show instead of file names in USB Device.
  • Partially blank screens.
  • The display changes to a black screen with blue letters.
These symptoms occur after you do these (4) things:
  1. Run a program in FNC mode.
  2. There is an alarm present.
  3. Press [EDIT].
  4. Press [LIST PROGRAM].
Issue 6
The display becomes black. Then it changes to red. The control does not accept key presses. This occurs after you rapidly delete programs in memory. For example, this occurs after you rapidly press ERASE PROGRAM and Y again and again (project # 47063.003)
Affected Products
Machine Model(s): Mills and Lathes with a Maincon PCB.
Part Number(s): Not relevant.
In Serial Number Range: Not relevant.
With a Build Date: Not relevant.
With Software Version: M18.00 / L11.00 and higher.
Action Summary
Parts Replaced: Not relevant.
Parts Returned to Haas: Not relevant.
Parts Reworked: Not relevant.
Parts Discarded: Not relevant.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
