MILLING CHUCKS AND COLLETS
HAAS TESTED. HAAS PROVEN.
SEE ALL MILLING CHUCKS AND COLLETS
  2. Mill Toolholding
  3. Milling Chucks & Collets
MILLING CHUCKS AND COLLETS OVERVIEW
Milling Chucks and Collets
Milling chucks are versatile, high-accuracy toolholders with very high gripping power and very low runout. They are great for heavy milling applications, and for holding larger diameter tool shanks. The solid one-piece construction and symmetrical design of the toolholder provide high accuracy and good balance characteristics.
Milling chucks are designed to hold a single size tool shank, and then precision straight-shank reducing collets are used to hold smaller diameter tools. The straight collet design provides even clamping along the entire length of the shank, eliminating axial movement of the tool, increasing rigidity, and minimizing runout. This results in high gripping force for heavy milling.
Simple twist-lock operation and high retention force make these milling chucks ideal for general purpose operations.
NOTE: Never tighten a milling chuck without a tool in the toolholder, or clamp on a tool that is too small for the holder or collet sleeve.
        Features:
  • Low runout
  • Simple twist-lock operation
  • High grip strength
  • Excellent tool retention
Toolholder and Pull Stud specifications
Toolholder Maintenance
Milling Chuck Instructions
Assembly
  1. Clean the inside of the milling chuck, collet, and tool.
  2. Insert the appropriate size collet and tool into the milling chuck.
  3. Tighten using the spanner wrench until the cap contacts the body of the chuck. Full-face contact must occur between the cap and the chuck body.
CAUTION
  • Never tighten the milling chuck cap without a tool inside of it — permanent damage will occur.
  • Only install smooth shank tooling into the milling chuck. Weldon flats and other side-lock style tooling will not be held with as much force and can cause the bore of the milling chuck to permanently deform.
Tool Removal
  1. Loosen the cap with the spanner wrench until the tool can be removed.
  2. Remove the tool.
  3. Loosen the cap until it’s out and continue to loosen it an additional 1 to 2 turns. This will re-align the bearings and ensure full and accurate clamping the next time the milling chuck is used.
Sale Items( 1 )
System of Measurement( 2 )
Item( 2 )
Taper( 4 )
[ØD] Bore Diameter( 15 )
[ØBD] Body Diameter( 6 )
Upgrade your milling operations with precision-engineered milling chucks. Our milling chucks are versatile, high-accuracy toolholders with very high gripping power and very low runout. They are great for heavy milling applications, and for holding larger diameter tool shanks. The solid one-piece construction and symmetrical design of the toolholder provide high accuracy and good balance characteristics, ensuring optimal performance in metalworking and manufacturing.
26 items
04-0067
CT40 1" Milling Chuck x 4-1/8" Gage Length, TSC
Part #: 04-0067
RETAIL PRICE: $131.95 $undefined
04-0068
CT50 1-1/4" Milling Chuck x 4-1/8" Gage Length, TSC
Part #: 04-0068
RETAIL PRICE: $288.95 $undefined
$231.97
04-0528
SK40/DIN 25mm Milling Chuck x 105mm Gage Length, TSC
Part #: 04-0528
RETAIL PRICE: $131.95 $2,498.95 $743.95 $99.95 $449.95 $1,049.95 $undefined
$112.97
04-0529
BT40 25mm Milling Chuck x 105mm Gage Length, TSC
Part #: 04-0529
RETAIL PRICE: $131.95 $2,048.95 $609.95 $81.95 $368.95 $860.95 $undefined
$112.97
1949.97
580.97
77.97
350.97
818.97
04-0530
SK40/DIN/BT40 Milling Collet, 6mm Bore Diameter x 25mm External Diameter
Part #: 04-0530
RETAIL PRICE: $23.95 $248.95 $74.95 $9.95 $44.95 $104.95 $undefined
$13.97
199.97
59.97
7.97
35.97
83.97
04-0531
SK40/DIN/BT40 Milling Collet, 8mm Bore Diameter x 25mm External Diameter
Part #: 04-0531
$13.97
199.97
59.97
7.97
35.97
83.97
04-0532
SK40/DIN/BT40 Milling Collet, 10mm Bore Diameter x 25mm External Diameter
Part #: 04-0532
$13.97
199.97
59.97
7.97
35.97
83.97
04-0533
SK40/DIN/BT40 Milling Collet, 12mm Bore Diameter x 25mm External Diameter
Part #: 04-0533
$13.97
199.97
59.97
7.97
35.97
83.97
04-0534
SK40/DIN/BT40 Milling Collet, 14mm Bore Diameter x 25mm External Diameter
Part #: 04-0534
$13.97
199.97
59.97
7.97
35.97
83.97
04-0535
SK40/DIN/BT40 Milling Collet, 16mm Bore Diameter x 25mm External Diameter
Part #: 04-0535
RETAIL PRICE: $21.95 $248.95 $74.95 $9.95 $44.95 $104.95 $undefined
199.97
59.97
7.97
35.97
83.97
04-0536
SK40/DIN/BT40 Milling Collet, 18mm Bore Diameter x 25mm External Diameter
Part #: 04-0536
$13.97
199.97
59.97
7.97
35.97
83.97
04-0537
SK40/DIN/BT40 Milling Collet, 20mm Bore Diameter x 25mm External Diameter
Part #: 04-0537
$13.97
199.97
59.97
7.97
35.97
83.97
04-1219
BT40 25mm Milling Chuck x 76mm Gage Length, TSC
Part #: 04-1219
RETAIL PRICE: $162.95 $3,498.95 $1,041.95 $139.95 $629.95 $1,469.95 $undefined
$114.97
2449.97
728.97
97.97
440.97
1028.97
04-1220
CT40 1" Milling Chuck x 3" Gage Length, TSC
Part #: 04-1220
RETAIL PRICE: $162.95 $undefined
$114.97
04-1221
SK40 25mm Milling Chuck x 80mm Gage Length, TSC
Part #: 04-1221
$114.97
2449.97
728.97
97.97
440.97
1028.97
06-0086
50-Taper Milling Chuck Spanner Wrench
Part #: 06-0086
RETAIL PRICE: $17.95 $373.95 $111.95 $14.95 $67.95 $156.95 $undefined
$8.97
274.97
81.97
10.97
49.97
115.97
06-0087
CT50 Milling Collet, 3/8" Bore Diameter x 1-1/4" External Diameter
Part #: 06-0087
RETAIL PRICE: $23.95 $undefined
$13.97
06-0088
CT50 Milling Collet, 1/2" Bore Diameter x 1-1/4" External Diameter
Part #: 06-0088
$14.97
06-0089
CT50 Milling Collet, 5/8" Bore Diameter x 1-1/4" External Diameter
Part #: 06-0089
$13.97
06-0090
CT50 Milling Collet, 3/4" Bore Diameter x 1-1/4" External Diameter
Part #: 06-0090
$13.97
