    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
    • 08-1760
      08-1760
      08-1760 View All
      • 08-1760
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Manual Chucks
      Manual Chucks Shop All
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    4. Español - Méjico
    14. пост-советский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
TR160-2
Product Image
GET QUOTE
TR160-2
    CNY ONLY
Dual-Platter 160 mm Trunnion Table
  • 2 Spindles
  • 160 mm Platter Size
  • 100 ft-lb Max Torque
  • 80 °/sec Max Speed
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • Rotary Fit chart
  • Gallery
  • Get Info
  • Layout Drawing
  • Operator’s Manual
  • 5-Axis Rotary Series Flyer
Standard Features
  • Direct Control by Mill CNC
  • Rotary Cable Support
Available Options
Automation Options
The TR160-2 is a dual-axis trunnion rotary table that offers maximum rigidity and accurate performance for 3+2 and full 5-axis machining of small to medium parts. The dual-spindle design allows two workpieces to be loaded and machined in a single setup. Scale feedback on the A (tilting) axis increases positioning accuracy and repeatability. The unit fits into VF-2 and larger VF Series machines (extended Z-axis clearance option highly recommended).
Note: Requires a Haas mill with 4th- and 5-axis drive and NGC software version 100.19.000.1100 or later for full 4th- and 5th-axis operation.
  • Add 4- and 5-axis capabilities to your machine
  • Dual spindles for increased productivity
  • Max weight per platter: 80 lb (36.3 kg)
  • Easy plug-and-play connection to Haas machines
  • Industry-leading performance and capabilities
  • Made in the USA
YES! NEW HAAS ROTARY PRODUCTS CAN BE USED ON OLDER HAAS MACHINES!
All new Haas rotary products are designed to integrate seamlessly with new and late model Haas machines, and are configured with the latest generation servomotors for best performance.
For use on older Haas machines, most new Haas rotary products may be configured with earlier generation servomotors, at additional cost. Please contact your local HFO for more details.
VIDEOS
Trunnion Rotary Table Model Guide
____________________________________________________
Don’t know where to start? Check out this video model guide to find the best one for
your needs!
RELATED PRODUCTS
Single Rotary Spindle, More Swing
Haas TR160
TR160
160 mm Dual-Axis Trunnion Table
  • 1 Spindles
    CNY ONLY
Learn More Build & Price
TILTING ROTARY TABLE
Haas TRT160
TRT160
160 mm Tilting Rotary Table
  • 1 Spindles
  • 112 ft-lb Max Torque
  • 104 °/sec Max Speed
    CNY ONLY
Different Approach
Haas TR200Y
TR200Y
Compact 200 mm Dual-Axis Trunnion Table
  • 1 Spindles
  • 200 mm Platter Size
  • 150 ft-lb Max Torque
  • 130 °/sec Max Speed
    CNY ONLY
CYLINDRICAL ENGRAVING USING G47/G107
Easily hand-program 4th-axis engraving on your Haas mill – without a CAM system. With G47 and G107, engraving on a cylindrical part couldn’t be easier.
UNWIND YOUR HAAS ROTARY QUICKLY
Today, Mark solves an issue every Haas Rotary user faces at some point: How do I get my rotary back to zero quickly?
How to Program a SAFE TOOL CHANGE POSITION
Mark shows how to command a safe tool change position to avoid crashing a tool into your fixture or rotary. It’s all done with a simple program, and referenced with an M-code.
Your new 5-axis compact rotary
If you make small parts and have multiple setups, this rotary is the perfect solution. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shops efficiency.
Platter S.A.E METRIC
Platter Diameter 6.30 in 160 mm
Max Weight on Platter 80 lb 36.3 kg
Part Swing Max 10.5 in 265 mm
Number of Std T-Slots 6 @ 60° 6 @ 60°
Spindle - A (tilt) S.A.E METRIC
Max Speed 80 °/sec 80 °/sec
Max Torque 150 ft-lbf 203 Nm
Backlash 30 arc-sec 30 arc-sec
Gear Ratio 63:1 63:1
Timing 2:1  2:1
Brake Torque @ 100 psi/6.9 bar 200 ft-lbf 271 Nm
Spindle - B (rotary) S.A.E METRIC
Number 2 2
Max Torque 100 ft-lbf 136 Nm
Runout Max 0.0005 in 0.013 mm
Timing 2:1  2:1
Brake Torque @ 100 psi/6.9 bar 100 ft-lbf 136 Nm
Indexing - A (tilt) S.A.E METRIC
Max Rotation/Step ± 120 ° ± 120 °
Resolution 0.001 ° 0.001 °
Accuracy (±) ± 15 arc-sec ± 15 arc-sec
Repeatability 10 arc-sec 10 arc-sec
Indexing - B (rotary) S.A.E METRIC
Max Rotation/Step (with rotary control) 999.999 ° 999.999 °
General S.A.E METRIC
Operating Temp (max ambient) 100 °F 38 °C
Air Pressure Max 150 psi 10.3 bar
Export Crate 49 in x 21 in x 25 in 125 cm x 54 cm x 64 cm
Weight 575 lb 261.0 kg
TR160-2 EC-1600 POSITIVE FIT
TR160-2 EC-1600ZT POSITIVE FIT
TR160-2 GR-510 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 GR-712 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 TM-3 POSITIVE FIT
TR160-2 TM-3P POSITIVE FIT
TR160-2 VF-10/40 POSITIVE FIT
TR160-2 VF-10/50 POSITIVE FIT
TR160-2 VF-11/40 POSITIVE FIT
TR160-2 VF-11/50 POSITIVE FIT
TR160-2 VF-12/40 POSITIVE FIT
TR160-2 VF-12/50 POSITIVE FIT
TR160-2 VF-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 VF-2SS ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 VF-2SSYT POSITIVE FIT
TR160-2 VF-2YT POSITIVE FIT
TR160-2 VF-3 POSITIVE FIT
TR160-2 VF-3SS POSITIVE FIT
TR160-2 VF-3SSYT POSITIVE FIT
TR160-2 VF-3YT POSITIVE FIT
TR160-2 VF-3YT/50 POSITIVE FIT
TR160-2 VF-4 POSITIVE FIT
TR160-2 VF-4SS POSITIVE FIT
TR160-2 VF-5/40 POSITIVE FIT
TR160-2 VF-5/40XT POSITIVE FIT
TR160-2 VF-5/50 POSITIVE FIT
TR160-2 VF-5/50XT POSITIVE FIT
TR160-2 VF-5SS POSITIVE FIT
TR160-2 VF-6/40 POSITIVE FIT
TR160-2 VF-6/50 POSITIVE FIT
TR160-2 VF-6SS POSITIVE FIT
TR160-2 VF-7/40 POSITIVE FIT
TR160-2 VF-7/50 POSITIVE FIT
TR160-2 VF-8/40 POSITIVE FIT
TR160-2 VF-8/50 POSITIVE FIT
TR160-2 VF-9/40 POSITIVE FIT
TR160-2 VF-9/50 POSITIVE FIT
TR160-2 VM-2 POSITIVE FIT
TR160-2 VM-3 POSITIVE FIT
TR160-2 VM-6 POSITIVE FIT
TR160-2 VF-2-I ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 VF-2-V ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 VF-2-EU ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 VF-2-SE ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 VF-4-I POSITIVE FIT
TR160-2 VF-4-V POSITIVE FIT
TR160-2 VF-4-EU POSITIVE FIT
TR160-2 VF-4-SE POSITIVE FIT
TR160-2 VF-4SS-V POSITIVE FIT
TR160-2 VF-2SS-V ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR160-2 VF-6SS-V POSITIVE FIT
TR160-2 VF-5/40-I POSITIVE FIT
TR160-2 VF-3-V POSITIVE FIT
TR160-2 VF-3SS-V POSITIVE FIT
TR160-2 VF-2YT-EU POSITIVE FIT
TR160-2 VF-2SSYT-EU POSITIVE FIT
TR160-2 VF-14/40 POSITIVE FIT
TR160-2 VF-14/50 POSITIVE FIT
TR160-2 VF-2SSYT-UK POSITIVE FIT
TR160-2 VF-4SS-UK POSITIVE FIT
TR160-2 VF-4SS-EU POSITIVE FIT
TR160-2 VF-2YT-V POSITIVE FIT
TR160-2 VF-2SSYT-V POSITIVE FIT
TR160-2 VF-5SS-V POSITIVE FIT
TR160-2 VF-5/40-V POSITIVE FIT
Need More Information?
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
