      • Coating Thickness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
EU-YT 4th-Axis Ready (VF-YT-EU 4TH AXIS)
Product Image
GET QUOTE
EU Model 4th-Axis Ready Package
    CNY ONLY
Everything you need to add a single-axis rotary to our extended Y-axis EU models
  • Overview
  • Send Info
HIGH-PRODUCTIVITY 4TH-AXIS READY PACKAGES
VF-1YT-EU and VF-2YT-EU
4TH-AXIS READY PACKAGE INCLUDES:
✓ Through-Spindle Coolant Ready
✓ Wireless Intuitive Probing System
✓ Chip Auger
✓ Coolant Maintenance Package
✓ 4th-Axis Drive
✓ Dynamic Work Offsets/Tool Center Point Control
✓ High-Speed Machining
✓ Programmable Coolant Nozzle
VF-1SSYT-EU and VF-2SSYT-EU
✓ Through-Spindle Coolant, 300 psi
✓ Chip Auger
✓ 4th-Axis Drive
Through-Spindle Coolant Ready / Through-Spindle Coolant (SS models)
Allows easy field installation of a Haas TSC system
Our Through-Spindle Coolant Ready option preconfigures your machine to accept an optional Haas Through-Spindle Coolant system. The TSC drawbar, plumbing, and wiring are preinstalled at the factory, making field installation of TSC faster, easier, and less invasive.
  • Allows easy field installation of a Haas TSC system
  • Includes the TSC drawbar, plumbing, and necessary wiring
  • Supports both Haas TSC systems: 300 psi and 1000 psi
  • Contact your local HFO for field installation
Learn more
Coolant through the tool, 300 psi
This Haas Through-Spindle Coolant system provides up to 300 psi (21 bar) of coolant to the cutting tool, allowing for heavier cuts, higher feedrates, deep-hole drilling, and better surface finishes. With Through-Spindle Coolant, you can really reduce your cycle times to increase throughput, and you’ll produce higher-quality parts. To minimize clogging, the Haas TSC pump includes an innovative self-cleaning feature. Maximum rpm with TSC enabled is 15,000 rpm.
  • Allows deep-hole drilling without pecking to reduce cycle times
  • Reduces material work hardening and increases tool life
  • Produces better surface finishes by clearing chips
  • Self-cleaning TSC pump
  • Requires three-phase pow
Learn more
The Advantages Of Through-Spindle Coolant
In this video, Scott and Matt demonstrate some of the advantages of the Haas TSC system by comparing traditional flood coolant and through-spindle coolant on the same drilling application.
How It Works - Through Spindle Coolan
In this installment of Haas How It Works, Mechanical Engineer Katherine White describes how the Haas TSC system works, the benefits of using TSC, and the proper applications for both 300 psi (20.7 bar) and 1000 psi (68.9 bar) systems.
Drastically reduce setup times with this complete probing package
Set up your Haas mill up to 5 times faster using the Haas Wireless Intuitive Probing System (WIPS). WIPS is a complete probing package that includes the spindle probe, tool setting probe, and optical machine interface, along with powerful software that guides the operator through the job setup process with intuitive, easy-to-use templates. WIPS allows you to quickly and easily define work offset coordinates, set tool length offsets, and perform in-process inspection, for both part inspection and tool breakage detection. WIPS is the single best productivity improvement you can add to your Haas mill.
  • Includes the Haas Visual Programming System, Macros, Spindle Orientation, and Coordinate Rotation & Scaling
  • Easy-to-use, built-in templates make programming probe functions simple
  • Fully automatic tool setting cycles
  • Includes Renishaw’s Inspection Plus software for programming advanced features, like in-process inspection
  • Includes our 50-Taper Tool Load Stand when ordered on 50-taper VMCs
Learn more
Wireless Probing How-To PART 1 - Calibrating the System
The Haas Wireless Intuitive Probing System (WIPS) is a game changer for shops wanting to increase the accuracy and speed with which they set tool and work offsets. Resident Applications expert John Nelson breaks down how WIPS works in this 1st part of our “WIPS How-To” series.
Troubleshoot Your Haas Probe
Mark further troubleshoots the wireless probing system for Haas mills (WIPS). Today, Mark discusses the importance of properly indicating-in your spindle probe, deciphers the infamous “Probe Fail” alarm, and offers some useful tips on how to properly place your table probe and workholding to avoid interference. If you have a probe system, or have ever considered adding one, you need to watch this video!
Keep your coolant clean and properly mixed.
Our Coolant Maintenance Package includes everything you need to keep your coolant system filled with properly mixed coolant, your tank free of tramp oil, and your enclosure clear of mist and smoke generated during the machine process.
  • Automatic Coolant Refill System – monitors the machine coolant level, and automatically adds correctly mixed coolant to the tank
  • Coolant Tank Oil Skimmer – automatically removes tramp oils from the surface of the coolant, extending coolant life and reducing coolant maintenance
  • Coolant Mist Condenser – keeps the machine’s interior clear of mist and smoke generated by machining, improving visibility and allowing faster workpiece exchange
Learn more
The Automatic Coolant Refill System
The Haas Automatic Coolant Refill System is designed to enhance the productivity of your shop by simplifying the way you make coolant. This option takes all the calculation, chemistry, and mixing out of the process. In this video, Andrew and Don go over some of the option’s key points, and explain why it’s an essential upgrade for your shop – saving you time and making you money.
The Haas Enclosure Exhaust System
Given the importance of cycle-time reduction these days, having to wait around for coolant mist to dissipate from a machine’s enclosure before changing parts is an expensive waste of time. That’s why Haas engineers designed an Enclosure Exhaust System that is easy to use, simple to maintain, and best of all, costs about half as much as what the competition offers.
Chip Auger
Chip Auger
Automatically remove chips from the machine
This auger-style chip conveyor automatically removes chips from the machine, while compressing them and wringing out the coolant. It is ideal for both short runs and high-production environments, eliminating the downtime required for manual chip removal. The auger can be activated via M-code or directly from the control pendant, and there are settings to control the interval and duration of the auger cycle for automatic operation. Smart-sensing technology automatically reverses the auger if a jam occurs.
  • Compresses chips, saving space in the chip bin
  • Lift angle minimizes coolant carryout
  • Automatically reverses if a jam occurs
  • Activated via M-code, or from the control pendant
  • Energy efficient via control settings for automatic operation
Learn more
AUGER – OPTION SPOTLIGHT
Here’s a quick look at the Haas Chip Auger option available on all Haas VMCs. If you want to spend more time making chips, and less time shoveling them out of your machine, check this out.
4th-Axis Drive
4th-Axis Drive and Wiring
Prepare your machine for 4th-axis capabilities
The fastest way to increase the productivity of your Haas mill is to add a Haas 4th-axis rotary product. The Haas 4th-axis drive allows the use of a fully integrated 4th-axis Haas rotary table or indexer for multi-sided machining, yielding increased productivity and reduced setups. The drive is fully integrated to the Haas control, allowing simple plug-n-play installation of a Haas rotary table or indexer. This option is field installable.
  • Fully integrated to the Haas Control
  • Reduces setups, increases accuracy, and increases throughput
  • Allows simple plug-n-play installation of a Haas rotary table or indexer
Learn more
Dynamic Work Offsets and Tool Center Point Control
Increase productivity and reduce setup times
Dynamic Work Offsets (DWO) and Tool Center Point Control (TCPC) are software features in the Haas control that make setting up 4- and 5-axis jobs as easy as setting up a 3-axis machine. They allow an operator to place the part and fixture anywhere on the machine’s table or platter, regardless of the location that was programmed in the CAM system. DWO and TCPC determine the difference between the centers-of-rotation programmed in the CAM system and the centers-of-rotation within the machine and apply the appropriate offsets.
  • Simplifies setup operations – part and fixture can be placed anywhere on the table / platter
  • Saves money by eliminating costly workholding, like self-centering fixtures
  • Eliminates the need to regenerate programs from the CAM system
  • Makes setting up 5-axis jobs as easy
Learn more
SIMPLIFY YOUR 3+2 AND 5-AXIS MACHINING
With DWO/TCPC, there’s no need to have thousands of lines of code to program a 5-axis part. With DWO/TCPC, the software keeps your tool at the correct programmed location, even when your part is moving in space. Check out this Haas Tip of the Day to see DWO/TCPC in action!
Don’t get left behind, speed up your processes
Learn more
GO FASTER
HSM lets your mill cut at maximum feedrates where possible, while slowing just enough, where necessary, to make sure complex part geometry is maintained.
No more manually adjusting coolant nozzles
Boost your productivity. Reduce cycle times. Eliminate all that opening and closing of the mill doors to adjust coolant lines. Our Programmable Coolant Nozzle is a multi-position nozzle that automatically directs coolant precisely at the cutting tool. The position of the nozzle is controlled via the program, and set specifically for each tool length – saving operator time by eliminating constant adjustments. The nozzle position may also be adjusted manually from the control pendant while a program is running
NOTE: If an Accessory Tooling Block is installed, it may prevent coolant from the Programmable Coolant Nozzle (PCOOL) from reaching short tools, when the nozzle is at the top of its travel.
  • Better chip clearing and tool life
  • Fully integrated with the Haas control
  • Store nozzle positions in the tool offset table
  • Coolant nozzle positions can be adjusted on-the-fly
  • Features 34 programmable positions
Learn more
Tricks You Didn’t Know About P-Cool – Haas Automation Tip of the Day
P-Cool can do a lot more then you think! If you’ve ever set your coolant position to drill a deep hole or mill a pocket, only to have the coolant hit the side of the part and not the tool, there’s a trick for that. How about a macro that automatically positions your P-Cool for every tool in the carousel? Mark shows how to do that, too!
Haas Automation Option Spotlight
Here’s a quick look at the Haas Programmable Coolant Nozzle option available on all Haas VMCs. Set the nozzle position for every tool in your program, and as each tool is called, the nozzle adjusts to aim right where you programmed it to. The result? No more adjusting coolant lines constantly, and you get coolant right where you need it.
ADD A 4TH-AXIS PACKAGE AND
GET 15% OFF ANY SINGLE-AXIS ROTARY!
Add a Single-Axis Rotary
Need More Information?
MORE TRAVEL | MORE CHOICES | MORE VALUE
EU SERIES – EXTENDED Y-AXIS
Machines configured, built, and priced just for Europe. You can’t get more personalized than that.
EXPLORE OTHER PACKAGES
