      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
6 - Autodoor - Door Track
Autodoor - Service Manual
  • 1 - Autodoor - Introduction
  • 2 - 8M Autodoor - Installation
  • 3 - CAN Autodoor - Installation
  • 4 - Autodoor - LVPS
  • 5 - Autodoor - Door Edge Sensor
  • 6 - Autodoor - Door Track
  • 7 - Autodoor - DC Motor
  • 8 - Autodoor - Maintenance
  • 9 - Autodoor - Troubleshooting
  • 6.1 Autodoor Door Track Replacement
DC Autodoor Track Replacement
AD0465
VMC AutoDoor Track Replacement (MVL 1505)
WARNING: You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
WARNING: Only authorized personnel with the proper training and certification should do this repair procedure.
All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
This procedure will show you how to replace the belt and track on a DC Autodoor machine.
Important: Download the latest configuration files to make sure you have the latest autodoor parameters.
Prerequisites
For VF-Small machines built prior to Sept 16, 2019 you will need to order the below parts in addition to the service kit.
Mill (VF-1 - VF-2)
  • 20-5512  Door Bumper Spacer qty 2
  • 40-1614  SHCS 1/4-20 X 1 1/4 qty 2
This Document Applies to the Following Kits:
  • 93-3089   AUTODOOR BELT TRACK KIT ST-10/15
  • 93-3091   AUTODOOR BELT TRACK KIT ST-20 2018
  • 93-3096   AUTODOOR BELT TRACK KIT ST-30 2019
  • 93-3101   AUTODOOR BELT TRACK KIT ST-30L/35L
  • 93-3092   AUTODOOR BELT TRACK KIT MILL S VF 2018
  • 93-3095   AUTODOOR BELT TRACK KIT MILL M VF 2018
  • 93-3272   AUTODOOR TRACK KIT VF-6/8
  • 93-3273   AUTODOOR TRACK KIT VF-7/9
  • 93-3274   AUTODOOR TRACK KIT VF-10/11
  • 93-3276   AUTODOOR TRACK KIT DT-1/DM-1
  • 93-2717   SRVC upgrade ST-10/15 NGC - Only for upgrading a machine from friction wheel to geared wheel auto door.
Replacement
Remove the Autodoor motor cover [1].
Disconnect the airlines from motor assembly.
Remove the autodoor motor assembly [2].
Remove the adhesive track [3] from the top of the door.
VF Installation
VF Series:
Peel and stick the double sided tape [1] on top of the door.
Install the door track [2] on top of the double sided tape.
Peel and stick the double sided tape [3] and center it on the autodoor track.
Place the belt [4] on top of the double sided tape, and make sure the belt is centered on the track.
Install the retaining clip [5] and screw [6] on each side of the belt.
Note: The lip of the retaining clip goes over the first tooth of the belt.
Install the autodoor motor assembly [7].
Install the autodoor motor cover [8].
VF-Small
For VF-1 to VF-2 machines built prior to 9/16/2019 you will need to install a door bumper spacer [2]  P/N 20-5512  and a longer screw [1] P/N 40-1614 on the outer end of each door.
NOTE: The spacer [2] and the screw [1] are NOT included in the kits:
Lathe Installation
Lathe Series:
Install the retaining clip [5] and nut [6] on each side of the belt.
DT/DM Installation
Peel and stick the double sided tape [1] on top of the door [9].
