28 - NGC - Control Icons
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - 115V LED - WorkLights
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 32 - NGC - Broken Tool Detection
  • 33 - NGC - IPFDM PCB
  • 34. NGC - LVPS
  • 36 - NGC - High Intensity Lights
  • Mill - Control Icon Guide
  • Lathe - Control Icon Guide
Icon Guide
Setup
Setup mode is locked; the control is in Run mode. Most machine functions are disabled or limited while the machine doors are open.
Setup
Setup mode is unlocked; the control is in Setup mode. Most machine functions are available, but may be limited while the machine doors are open.
Cycle Door
The door must be cycled at least once to ensure that the door sensor is working. This icon appears after [POWER UP] If the user has not yet cycled the door.
Door Open
Warning, door is open.
Pallet Load Door Open
The pallet load station is open.
Light Curtain Breach
This icon appears when the machine is idle and the light curtain is triggered. It also appears when a program is running and the light curtain is running. This icon disappears when the obstacle is removed from the light curtain line of sight.
Light Curtain Hold
This icon appears when a program is running and the light curtain is triggered. This icon will clear the next time [CYCLE START] is pressed.
Running
The machine is running a program.
Jog
An axis is jogging at the current jog rate.
APL Mode
This icon appears when the machine is in APL Mode.
Power Saving
The power-saving servos-off feature is active. Setting 216, SERVO AND HYDRAULIC SHUTOFF, designates the time period allowed before this feature activates. Press a key to activate the servos.
Jog
This icon appears while the control returns to the workpiece during a run-stop-jog-continue operation.
Jog
You have pressed [FEED HOLD] during the return portion of a run-stop-jog-continue operation.
Jog
This icon prompts you to jog away during a run-stop-jog-continue operation.
Feed Hold
The machine is in feed hold. Axis motion has stopped, but the spindle continues to turn.
Feed
The machine is executing a cutting move.
Rapid
The machine is executing a non-cutting axis move (G00) at the fastest possible rate. Overrides can affect the actual rate.
Dwell
The machine is executing a dwell (G04) command.
Restart
The control scans the program before a restart if Setting 36 is ON.
Singbk Stop
SINGLE BLOCK mode is active, and the control needs a command to continue.
Door Hold
Machine motion has stopped because of door rules.
Jog Lock
Jog lock is active. If you press an axis key, that axis moves at the current jog rate until you press [JOG LOCK] again, or the axis reaches its limit.
Remote Jog
The optional remote jog handle is active.
Vector Jog
For five-axis machines, the tool will jog along the vector defined by the rotary positions.
Low Gearbox Oil Flow
This icon appears when low gearbox oil flow persists for 1 minute.
Low Gearbox Oil
The control detected a low gearbox oil level.
Note: In software version 100.19.000.1100 and higher the control will monitor the gearbox oil level condition when spindle fan is turned OFF. After the spindle fan turns off, there is a delay before the gearbox oil level monitoring will begin. Press [RESET] to clear the low gearbox oil icon.
Rotary Lube
Check and fill the rotary table lubrication oil reservoir.
Dirty TSC/HPFC Filter
Clean the Through-Spindle Coolant or High-Pressure Flood Coolant filter.
Low Coolant Concentrate
Fille the concentrate reservoir for the coolant refill system.
PulseJet Low Oil
This icon appears when the system detects a low oil condition on the PulseJet oil reservoir.
Low Lube
The spindle lubrication oil system detected a low oil condition, or the axis ball screw lubrication system detected a low oil or low pressure condition.
Inspect the spindle and axis lubrication oil reservoirs for the correct oil level.  If levels are correct refer to the Spindle Lubrication - Troubleshooting Guide or Haas Oil Axis Lubrication - Troubleshooting guide for more troubleshooting information.
Low Oil
The rotary brake oil level is low.
Residual Pressure
Before a lubrication cycle the system detected residual pressure from the grease pressure sensor. This can be caused by an obstruction in the axes grease lubrication system.
Mist Filter
Clean the mist extractor filter.
Vise Clamp
This icon appears when the vise is commanded to clamp.
Low Coolant (Warning)
Coolant level is low.
Low Pulsejet Oil
The Pulsejet oil level is low.
Mist Condenser
This icon appears when the mist condenser is turned on.
Low Air Flow
Inch Mode - Air flow is not sufficient for correct machine operation.
Low Air Flow
Metric Mode - Air flow is not sufficient for correct machine operation.
Spindle
When you press [HANDLE SPINDLE], the jog handle varies the spindle override percentage.
Feed
When you press [HANDLE FEED], the jog handle varies the feed rate override percentage.
Handle Scroll
When you press [HANDLE SCROLL], the jog handle scrolls through the text.
Mirroring
Mirroring mode is active. Either G101 is programmed or Setting 45, 46, 47, 48, 80, or 250 (mirror image of axis X, Y, Z, A, B, C) is set to ON.
Brake
A rotary axis brake, or a combination of rotary axis brakes, is unclamped.
Brake
A rotary axis brake, or a combination of rotary axis brakes, is clamped.
HPU Oil Low
The HPU oil level is low. Check the oil level and add the recommended oil for the machine.
HPU Oil Temperature (Warning)
The oil temperature is too high to reliably operate the HPU.
Spindle Fan Failed
This icon appears when the spindle fan stops operating.
Electronics Overheat (Warning)
This icon appears when the control has detected cabinet temperatures are approaching levels that are potentially dangerous to the electronics. If the temperature reaches or exceeds this recommended level alarm 253 ELECTRONICS OVERHEAT will be generated. Inspect the cabinet for clogged air filters and correctly operating fans.
Electronics Overheat (Alarm)
This icon appears when the electronics remains in the overheat state for too long. The machine will not operate until the condition is corrected. Inspect the cabinet for clogged air filters and correctly operating fans.
Transformer Overheat (Warning)
This icon appears when the transformer is detected to be overheated for more than 1 second.
Transformer Overheat (Alarm)
This icon appears when the transformer remains in the overheat state for too long. The machine will not operate until the condition is corrected.
Low Voltage (Warning)
The PFDM detects low incoming voltage. If the condition continues, the machine cannot continue to operate.
Low Voltage (Alarm)
The Power Fault Detect Module (PDFM) detects incoming voltage that is too low to operate. The machine will not operate until the condition is corrected.
High Voltage (Warning)
The PFDM detects incoming voltage above a set limit, but still within operating parameters. Correct the condition to prevent damage to machine components.
High Voltage (Alarm)
The PFDM detects incoming voltage that is too high to operate and could cause damage to the machine. The machine will not operate until the condition is corrected.
Surge Protector Fault Detected
Indicates a Surge Protector Fault has been detected. This icon is active until the fault has been cleared.
Warning: If continuing to use the machine in this state. The electronics are capable of being damaged due to any electrical surge.
Robot Battery is Low
Robot Battery is Low. Please replace the pulse coder batteries as soon as possible. Do NOT turn off the robot, otherwise it may require remastering. Reference 9156.062 ROBOT COMMAND FAILED SRVO-062 BZAL alarm in service documentation for more information.
Motion Sensor Battery is Low
Motion sensor battery is low. Batteries can not be replaced on a motion sensor contact your HFO to order a replacement.
NOTE: Geolocation will need to be validated.
Motion Sensor Battery is Depleated
Motion sensor battery is depleated. Batteries can not be replaced on a motion sensor contact your HFO to order a replacement.
Low Air (Warning)
The air pressure to the machine is too low to reliably operate pneumatic systems. Correct this condition to prevent damage to or incorrect operation of pneumatic systems.
Low Air (Alarm)
The air pressure to the machine is too low to operate pneumatic systems. The machine will not operate until the condition is corrected. You may need a higher-capacity air compressor.
High Air (Warning)
The air pressure to the machine is too high to reliably operate pneumatic systems. Correct this condition to prevent damage to or incorrect operation of pneumatic systems. You may need to install a regulator at the machine’s air input.
High Air (Alarm)
The air pressure to the machine is too high to operate pneumatic systems. The machine will not operate until the condition is corrected. You may need to install a regulator at the machine’s air input.
Pendant E-Stop
[EMERGENCY STOP] on the pendant has been pressed. This icon disappears when [EMERGENCY STOP] is released.
APC E-Stop
[EMERGENCY STOP] on the pallet changer has been pressed. This icon disappears when [EMERGENCY STOP] is released.
Tool Changer E-Stop
[EMERGENCY STOP] on the tool changer cage has been pressed. This icon disappears when [EMERGENCY STOP] is released.
Auxiliary E-Stop
[EMERGENCY STOP] on an auxiliary device has been pressed. This icon disappears when [EMERGENCY STOP] is released.
Remote Jog Handle-XL (RJH-XL) E-Stop
[EMERGENCY STOP] on the RJH-XL has been pressed. This icon disappears when [EMERGENCY STOP] is released.
Single Blk
SINGLE BLOCK mode is active. The control executes programs (1) block at a time. Press [CYCLE START] to execute the next block.
Tool Life (Warning)
The tool life remaining is below Setting 240, or the current tool is the last one in its tool group.
Tool Life (Alarm)
The tool or tool group has expired, and no replacement tools are available.
Opt Stop
OPTIONAL STOP is active. The control stops the program at each M01 command.
Blk Delete
BLOCK DELETE is active. When Block Delete is On, the control ignores (does not execute) the code following a Forward Slash (/), on that same line.
TC Door Open
The side-mount tool changer door is open.
TC Manual Mode
This icon appears when the tool carousel is in manual mode via the auto/manual switch. This swich is only on machines with tool cages.
TL CCW
The side-mount tool changer carousel is rotating counter-clockwise.
TL CW
The side-mount tool changer carousel is rotating clockwise.
Tool Change
A tool change is in progress.
Tool Unclamped
The tool in the spindle is unclamped.
Probe
The probe system is active.
Conveyor Fwd
The conveyor is active and moving forward.
Conveyor Rev
The conveyor is active and moving in reverse.
TSC
The Through-Spindle Coolant (TSC) system is active.
TAB
The Tool Air Blast (TAB) system is active.
Air Blast
The Auto Air Gun (AAG) is active.
HIL Light
Indicates the optional High Intensity (HIL) are turned ON and the doors are open. Duration is determined by Setting 238.
The main coolant system is active.
DC Drawbar Low Hydraulic Fuild Level
Drawbar failed to unclamp and the drawbar’s hydraulic fluid is low.
Icon Guide
Setup
Setup
Bar Feeder is Not Aligned
This icon appears when the bar feeder is enabled and out of position. Make sure the bar feeder is aligned with the feeding hole.
Bar Feeder Cover is Open
This icon appears when the bar feeder is enabled and the bar feeder cover is open
Bar Feeder is Out of Bars
This icon appears when the bar feeder has run out of the bars.
Cycle Door
Door Open
Light Curtain Hold
Running
Jog
Jog Warning
This icon appears when setting 53, Jog W/O Zero Return, is set to ON and the machine is in handle jog mode.
Note: Setting 53, Jog W/O Zero Return, is set to ON automatically if APL hardware is installed and the machine has not been zeroed.
APL Mode
Power Saving
Jog
Jog
Jog
Feed Hold
Feed
Rapid
Dwell
Singbk Stop
Door Hold
Restricted Zone
A current axis position is in the restricted zone.
Remote Jog
The icon appears when low gearbox oil flow persists for 1 minute.
Low Gearbox Oil
Note: The control only monitors the gearbox oil level condition at power-on. Once the gearbox low oil condition is detected, the icon will clear on the next power on when a normal level condition is detected.
Dirty HPC/HPFC Filter
Clean the High-Pressure Coolant or High-Pressure Flood Coolant filter.
Fill the concentrate reservoir for the coolant refill system.
Low Lube
Low Oil
Residual Pressure
HPU Oil Low
The HPU oil level is low. The HPU oil level is low. Check the oil level and add the recommended oil for the machine.
Mist Filter
Clean the mist extractor.
Low Air Flow
Low Air Flow
Spindle
Feed
Handle Scroll
Mirroring
Secondary spindle swap with Z-Axis mirroring active.
Mirroring
Mirroring mode is active. Either G101 is programmed or Setting 45, 46, 47, 48, 80, or 250 (mirror image of axis X, Y, Z, A, B, or C) is set to ON.
Chuck Unclamp I.D.
The chuck is unclamped.
Note: This icon is used when Setting 282, Main Spindle Chuck Clamping, is set to I.D.
Chuck Unclamp O.D.
 Note: This icon is used when Setting 282, Main Spindle Chuck Clamping, is set to O.D.
C-Axis Engaged
The C-Axis is engaged.
Spindle Fan Failed
The PFDM detects low incoming voltage. If the condition continues, the machine cannot continue operation.
Low Voltage (Alarm)
Low Air (Warning)
Low Air (Alarm)
High Air (Warning)
High Air (Alarm)
Pendant E-Stop
Auxiliary E-Stop
Chamfer Mode
This icon appears when the e-wheel is in chamfer mode.
Single Blk
Tool Life (Warning)
The tool life remaining is below Setting 240 or the current tool is the last one in its tool group.
Tool Life (Alarm)
The tool or tool group has expired and no replacement tools are available.
Opt Stop
Blk Delete
BLOCK DELETE is active. The control skpid program blocks that begin with a slash (/).
Tool Change
Probe
Parts Catcher
The parts catcher is activated.
Tailstock Hold
The tailstock is engaged with the part.
Conveyor Fwd
Conveyor Rev
HPC
The High-Pressure Coolant system is active.
Air Blast
The Air Blast is active.
HIL Light
Indicates the optional High Intensity Lights (HIL) are turned ON and the doors are open. Duration is determined by Setting 238.
