31 - NGC - Keypad
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - 115V LED - WorkLights
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 32 - NGC - Broken Tool Detection
  • 33 - NGC - IPFDM PCB
  • 34. NGC - LVPS
  • 36 - NGC - High Intensity Lights
  • 31.1 Rubber Keypad - Replacement
  • 31.2 Keypad - Troubleshooting
31.1 Keypad - Rubber-Type - Replacement
AD0654
Rev A - 11/2025
This procedure tells you how to replace the rubber-type keypad on the control pendant.
Tools Required:
  • Electrostatic Discharge (ESD) strap
  • Putty knife
Parts Required:
  • 93-61-0201: Mill Keypad Rubber Type
  • 93-61-0202: Lathe Keypad Rubber Type
Removal
Press [POWER OFF].
CAUTION: Use an electrostatic discharge (ESD) strap when you touch electronic components.
Remove the rear panel from the control pendant assembly.
Remove the front panel from the control pendant assembly.
Disconnect the 24-pin ribbon cable from the keypad PCB.
Use a putty knife or a small flat screwdriver to carefully remove the rubber keypad.
Carefully pull out the 24-pin ribbon cable through the opening of the control-pendant panel.
 NOTE: Carefully remove the tamper-proof sticker attached to the 24-pin ribbon cable. See HSG-A 11/04/2025 for more information.
Insert the 24-pin ribbon cable through the opening of the control-pendant panel.
Connect the 24-pin ribbon cable into the keyboard PCB.
NOTE: Be careful when you insert the ribbon cable connector into the connector of the keypad PCB. Make sure you do not bend the pins.
Press [POWER ON].
Make sure the keypad operates.
Press [POWER OFF].
Remove the cover of the adhesive strip on the rear of the keypad. Use the upper right corner of the keypad recess to align the keypad. Press the keypad into position.
Install the rear and front covers.
Press [POWER ON].
Make sure the keypad operates. If it does not work, contact your Haas Factory Outlet.
31.2 Keypad - Troubleshooting Guide
Keypad - Troubleshooting Guide - NGC
TG0091
Keyboard I/O Tab
Under Diagnostics, there is a Keyboard I/O tab that provides information on all the keyboard I/O input and output signals.
Each input and output is listed with its description and a value. If the value is 1, the input/output is triggered. If the value is 0, the input/output is not triggered.
The RJH is an extension of the keyboard, therefore the RJH outputs are included in this tab. The inputs are triggered by the user on the RJH, while the value of the output is listed--either 0 or 1 again.
These I/O signals can be used to better troubleshoot the system.
Key History Tab
Under Alarms, there is a Key History tab that keeps track of any used key. This keeps a record of each key used and the date & time it was used at.
This information can be helpful to test keypad function or to troubleshoot a specific alarm or problem.
A keypad button sticks or does not actuate when pressed.
The flex cable from the keypad to SKBIF PCB is damaged.
Inspect the cables and the connections.
The dome for a specific key fails to make a contact.
Alarm 546 Serial Keyboard Buffer Overflow One or more keys are stuck. Go to the Key History and see if there are keystrokes being generated without the buttons being pressed.   For NGC press the [ALARMS] button and go to the Key History tab.  Find out which key is getting stuck and determine if the keypad is defective.
Machines with SKBIF Version 6.xx.  Alarm 546 SERIAL KEYBOARD BUFFER OVERFLOW. The SKBIF firmware is outdated. Make sure you have SKBIF firmware version 6.6 or higher.  Refer to SKBIF PCB / RJH Firmware Update - NGC procedure.
Pressing on the bezel activates keys or makes a popping sound. The keypad is misaligned. Follow the instructions in the section Keypad Alignment below.
Cable Connections
Corrective Action:
If any of the 24 wires fail to make connection, or if they have an intermittent connection, the keypad will malfunction.
  • Make sure the pins in the connector [1] on the SKBIF is in good condition.
  • Make sure the flex cable [2] is in good condition. A broken trace or open contact will cause a row or column to be inoperative.
  • Replace the keypad if the cable is damaged.
Keypad Alignment
Loosen the outermost screws on the bottom half of the bezel as shown.
Adjust the keypad as needed so the keys are centered.
When the keypad has been centered, install the remaining screws.
