    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
    • Deals Of The Week
      Deals Of The Week Shop All
      • Grooving Tools
      • Cut-Off Tooling
      • Boring Bars
      • OD Toolholders
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
15 - NGC - 320V Power Supply
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration and Patch Files
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - WorkLights and HIL
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 320V Power Supply - Replacement
  • 320V Power Supply - Troubleshooting
320V Power Supply Replacement - (93-32-5557B)
AD0422
This procedure will show you how to replace 320V Power Supply on a Next Generation Control.
This Document Applies to these Parts:
  • 93-32-5557B
Electrical Safety
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Replacement / Installation - NGC
  1. [POWER OFF] the machine  and wait until the High Volt light is completely turned off.
  2. Mark and remove all the cables from the 320V Power supply.
     Note:  The new 320V Power Supply [1] does not need the +12VDC supply that was connected to J3 on the old power supply.
  3. Install the new 320V Power Supply [1].
  4. Connect the PS Fault cable to J4 [2].
  5. Install the VMON cable that comes in the kit and connect it to J2 [3].
  6. Connect the Regen cable [4] to the terminal strip.
     Note:  For machines that had the molex connectors use the Regen cable extension P/N 33-0470 that comes in the kit.
  7. Connect the 320VDC cable [5] to the terminal strip.
     Note:  For machines that had the molex connectors use the 320VDC cable  P/N 33-04902E that comes in the kit.
  8. Connect the 230VAC Input cable [6] to the terminal strip.
     Note:  For machines that had the molex connectors use the Power extension cable P/N 33-0469 that comes in the kit
  9. Connect the Ground cable and make sure all terminals are tight.  [POWER ON] and test the machine operation.
Overview
The High Voltage Power Supply (MMPS - MINIMILL Power Supply) is the source of power for the servo amplifiers.
It operates with 3 phase 208Vac or 240Vac single phase power. It rectifies the incoming AC power and supplies 320-340Vdc to the servo amplifiers.
The High Voltage Power Supply also contains the regeneration circuit used for dynamic braking.
Types of 320V Power Supplies:
  1. 32-5557 320V Power Supply (Molex Connectors)
  2. 32-5566 320V Power Supply ( Terminal Strip)
  3. 32-5566A 320V Power Supply (Terminal Strip with Fuse)
    Important: Do not discharge the 32-5566A MMPS using a resistor, this will cause the fuse to blow.  Instead wait until the HV led light has turned off.
Electrical Safety
Alarm 648 DC BUS SHORTED and Alarm 160 LOW INCOMING AC LINE VOLTAGE There is a problem with the DC Bus or the MMPS is shorted. Compare the measured DC voltage to the Diagnostic page.
Inspect the MMPS for short circuits
Alarm 647 REGEN LOAD SHORTED There is a problem with the REGEN or the MMPS is shorted. Measure the resistance across the REGEN load
Alarm 119 INPUT AC LINE OVERVOLTAGE and Alarm 650 DC BUS OVER VOLTAGE There is a problem with the REGEN or the MMPS is faulty. Measure the resistance across the REGEN load.
Incorrect DC Buss Voltage Display on the Gauge The incoming line voltage is low.  Measure the incoming line voltage and determine if is within specification.  For 480V machines check the transformer taps, to make sure they are set to the correct range.
The voltage monitor cable is not plugged in or not connected incorrectly. Use the electrical diagrams to make sure the Vmonitor cable is connected correctly.
The 320V power supply is not putting out the correct voltage signal. The 320V power supply will produce approximately 1VDC for every 100VAC.  If not the drive is defective.
DC BUS
Corrective Action:
Diagnostic DC Voltage Check
  1. Press the [POWER ON] button.
  2. Measure the DC voltage between pins 1 and 2 of connector J4 on the MMPS.
  3. Compare the measured voltage with the DC VOLTAGE on the diagnostics page on the control. The readings must match +-2%.
  4. Press the [POWER OFF] button.
  5. Disconnect the DC Bus cables from connector J3 on the MMPS.
  6. Press the [POWER ON] button.
  7. Monitor the DC VOLTAGE on the diagnostics page of the control. If the readings do not match, the problem can be:
    • A bad connection on the cable that carries the voltage monitor signal to the controller PCBs. Make sure there is a tight connection on the J6 connector on the MMPS and the J16 on the NGC Maincon PCB.
    • A faulty MMPS if you have incorrect voltage at J16 on the NGC Maincon PCB.
    • A faulty NGC Maincon PCB if you have the correct voltage on the cable at the J16 on the NGC controller PCB. There is 0.01 VDC for every 1 VDC Bus. For example, 320 VDC must show 3.2VDC.
Low DC Buss caused by shorted Amplifiers Check
  1. Press the [POWER OFF] button.
  2. Disconnect the DC Bus cables from connector J3 on the MMPS.
  3. Press the [POWER ON] button.
  4. Monitor the DC VOLTAGE on the diagnostics page of the control.
    • If the DC Bus goes back to the nominal value, there is a short in one of the servo amplifiers. A low resistance or a short is a sign of a faulty servo amplifier.
    • If the readings match and the alarm continues, then the problem is a faulty MMPS.
Short Circuit Inspection
Corrective Action:
Inspect the MMPS. Disconnect all cables from the MMPS.
Bridge rectifier to chassis check.
  1. Set your meter to resistance mode (Ohms).
  2. Check terminals 1, 2, and 3 to chassis ground. If the reading does not show an open circuit (O.L) the MMPS is damaged.
Bridge rectifier to DC bus terminal check
  1. Set the meter in diode test mode.
  2. Put the black lead on J3 pin 2. With the red lead, check terminals 1, 2, and 3 of J1.
  3. Wait until the reading on your meter settles. If the meter does not show show an open circuit (O.L) the MMPS is damaged.
  4. Put the black lead on J3 pin 1. With the red lead, check terminals 1, 2 & 3 of J1.
  5. Wait until the reading on your meter settles. If the meter does not show show an open circuit (O.L) the MMPS is damaged.
REGEN Load Inspection
Corrective Action:
REGEN Load Check:
  1. Set the meter to resistance mode (Ohms).
  2. Disconnect the REGEN load from the MMPS from connector J5.
  3. Measure the resistance across the leads. The reading must be between 9.5 and 12.5 ohms. If the REGEN load is within specification, there can be a problem with the MMPS.
  4. Measure the resistance across pins 1 on J3 and pin 3 of J5 of the MMPS. A short is a sign of a faulty MMPS.
Electrical Diagrams
320V Power Supply Diagram (32-5566 / 32-5566A)
320V Power Supply Diagram (32-5557)
320V Power Supply - Voltage Monitor Cable - 33-5790C
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
