6 - NGC - Error Report and Backup
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - 115V LED - WorkLights
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 32 - NGC - Broken Tool Detection
  • 33 - NGC - IPFDM PCB
  • 34. NGC - LVPS
  • 36 - NGC - High Intensity Lights
  • 6.1 Error Report
  • 6.2 Machine Data Backup
6.1 Error Report
Error Report - Next Generation Control
The following document will show you how to generate and Error Report and what is used for.
Alarm History - Alarms & Notifications
The following service video shows how to view alarm history and system notifications.
Note:  This service video is for reference only and does not replace the written procedure.
Error Reports
Haas machines with the Next Generation Control (NGC) can create an error report that saves the state of the machine for analysis. The error report is a ZIP file that includes a screenshot, the active program, and other information for diagnostics and system debugging. Train your customers to create this file immediately after a crash, a control freeze, an alarm, or when an apparent software bug appears.
Be sure always to generate the error report with the alarm active.
If the control freezes and does not respond to input:
  1. Take a digital photograph of the control screen.
  2. Cycle power.
  3. Immediately generate an error report.
Use these steps to generate an error report:
  1. Put a USB memory device into the USB port. The USB memory device is not required to generate an error report; without it, the control saves the error report in User Data, and you can retrieve it over Net Share or with a USB memory device.
  2. Press [SHIFT].
  3. Press [F3].
Send the ZIP file and digital photo to [email protected] for analysis.
Auto Error Report
This feature is only available in Software Version 100.23.000.1200 or higher:
Haas machines with Next Generation Control (NGC) can automatically create an error report that saves the machine's state for analysis whenever a specific alarm is triggered.
Go to the Alarm Viewer tab.
Highlight the desired alarm and press [ENTER] [1] to check it for auto error report.
Multiple alarms can be set for an automatic error report. Press [ALTER] [2] to filter all set alarms.
 Important: This feature disarms at every power up. For continuous monitoring, it is necessary to re-arm the feature after a power cycle.
Important: If a USB is inserted, auto error reports are saved in the USB folder on the Haas pendant. If no USB is inserted, auto error reports are saved in the List Program > User Data tab within a folder called AutoSavedErrorReports. Only five error reports can be saved in this folder at a time.
Error Report Screenshot
The screenshot of the error report contains useful information if it is taken at the correct time.
  • Always generate the error report with the alarm active.
  • The screenshot is an example of a correctly generated error report.
  • You can see the active alarm, the program that was running, and the line of the program where the alarm occurred.
6.1 Machine Data Backup
Machine Data Backup - NGC
Applies to machines built from: September, 2015
Back Up Machine
Use this procedure to backup all of the machine files on your Next Generation Control machine.
Set Setting 155, Load Pocket Tables, to ON.
 Note: Make sure the memory lock key switch is in the unlocked position.
Push [LIST PROGRAM].
Use the cursor arrows to select the USB tab [1].
Push [F4], System [2].
Use the up and down cursor to select Back Up Machine [3].
Push [ENTER].
Important Information
  • The next step puts the copies of the machine data files in the open directory on the USB memory device.
  • The backup makes a .zip file. You can open this .zip file on the control or on a PC.
  • The name of the .zip file that contains the backup data has this structure: "HaasBackup", then the date. For example, HaasBackup(xx-xx-xxxx).zip.
  • You cannot make a backup file if the control is in MEMORY or USER DATA modes.
This screen lets you select the data files to make copies of.
 Caution: If the machine has software version 100.15.000.1011, DO NOT select User Data [2] when you make a backup. Go to the User Data tab [1]. Select the User Data files to backup. Push [F2] to copy the files to the USB memory device.
Use the up and down cursors to make a selection.
Push [ENTER] to select or deselect what you must backup.
Push [F4] to make the backup.
Know this information about the stored data.
  • System Data makes copies of these data files:
    • settings
    • offsets
    • macro variables
    • advanced tool management (ATM)
    • alarm history
    • key history
    • linear screw compensation (LSC)
    • network configurations
  • User Data makes copies of all the files in the User Data folder.
  • Programs makes copies of all the files in the Memory folder.
  • The approximate size of each selection shows on the right side of the display. The total Estimated size shows at the bottom.
  • If a selection is too large for the USB memory device, it is grey.
