11 - NGC - 4th and 5th Axis
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - 115V LED - WorkLights
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 32 - NGC - Broken Tool Detection
  • 33 - NGC - IPFDM PCB
  • 34. NGC - LVPS
  • 36 - NGC - High Intensity Lights
  • 11.1 4th and 5th Axis Drive - Installation
  • 11.2 Rotary - Enable and Disable
  • 11.3 Reverse Rotary Direction - Setup
4th and 5th Axis Drive - Installation - NGC
AD0319
Revision A - 10/2025
Refer to the Rotary - Installation procedure to install a TR, TRT, or a T5C rotary unit on a Haas VMC.
Machine Requirements:
  • Mills that have brushless servo amplifiers.
  • Machines with NGC.
Document Applies to these parts:
  • P/N 93-2389 4TH-AXIS DRIVE, NGC
  • P/N 93-1000276 4TH-AXIS DRIVE
  • P/N 93-2544 5TH-AXIS DRIVE, NGC
  • P/N 93-1000275 5TH AXIS DRIVE
Note: All machines must be geolocated by a service technician when a 5th axis upgrade is installed and activated.
Motion sensor support has been posted on HBC in HBC -> Service -> Utilities -> Documents and software -> 11_Geolocation & Motion Sensor.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Rotary Scale Cable - Installation
Machine Compatibility:  Next Generation Control Machines with a trunnion rotary.
Document Applies to these Parts:
[A] 32-10053 QTY: 1 CABLE, [+12V] ROTARY SCALE FEEDBACK CONTROL END (NGC)
[B] 41-0040 QTY: 4 BOLT, PTHS 4-40X3/8 TRUSS MCMASTER-CARR
Find the plug [1] for the 4th-AXIS SCALE / A-AXIS SCALE or 5th-AXIS SCALE / B-AXIS SCALE receptacle. The plug is on the side of the control cabinet. Pull the plug out of the hole.
Connect the 28-pin connector [2] from the rotary scale feedback cable to the receptacle. Use the (4) 4-40 screws [3].
Remove the center cable track cover and the track cover below the MainCon PCB.
Remove the MainCon PCB cover.
Route the 4th-AXIS SCALE / A-AXIS SCALE or 5th-AXIS SCALE / B-AXIS SCALE cable [1] as shown.
Connect the 11-pin connector of the rotary scale feedback cable to the correct connector on the MainCon PCB:
  • 4th-AXIS SCALE / A-AXIS SCALE Scales Channel 12A (P36)
  • 5th-AXIS SCALE / B-AXIS SCALE Scales Channel 13A (P37)
Install the covers.
4th Drive - Installation - Mill
Find the (2) plugs [1] for the 4th-Axis / A-Axis receptacles. The plugs are on the side of the control cabinet. Push the plugs out of the holes.
Install the 7-pin power connector [2] into the receptacle that has the label 4th-AXIS POWER / A-AXIS POWER. Use the (4) screws.
Install the 28-pin encoder connector [3] in the receptacle that has the label 4th-AXIS ENCODER / A-AXIS POWER. Use the (4) screws.
Remove the I/O PCB cover.
Remove the Maincon PCB cover.
Find the location on the amplifier bank that has the A Axis / 4th Axis label. Install the amplifier for the fourth-axis drive at this location.
Connect the fourth-axis servo cable wires to the high-voltage terminals on the amplifier:
  • red to RED [1]
  • white to WHT [2]
  • black to BLK [3]
Connect jumpers [4] from the fourth-axis drive to the nearest amplifier on each side:
  • Connect the black wire to -H.V..
  • Connect the red wire to +H.V..
Put the cables in the cable tray.
Connect the 3-pin connector [1] on the A-Axis brake cable to P16 [2] on the I/O PCB.
Connect the 16-pin connector [4] on the encoder cable to Encoder Channel 4 (P20) [3] on the Main Control PCB.
Connect the 8-pin connector [5] on the current-command cable to the Amplifier Channel 4 (P4) socket [6] of the Main Control PCB.
Connect the 8-pin connector [7] on the current-command cable to the ampifier [8].
Remove the blanking plate [1].
Install the clamp block mount [2].
Put the rotary cables through the clamp block [3].
Install the clamp block retainer [4].
If you are not installing a fifth-axis drive, install the cover plates for the Maincon PCB and I/O PCB.
Set the main circuit breaker to the ON position.
Push [POWER ON].
Refer to: Next Generation Control - Option Activation Code to enable the fourth axis software.
5th Drive - Installation - Mill
Find the (2) plugs [1] for the 5th-Axis / B-Axis sockets. The plugs are on the side of the control cabinet. Pull the plugs out of the holes.
Install the 7-pin power connector [2] in the location that has the label 5th-AXIS POWER / B‑AXIS POWER. Use the (4) screws.
Install the 28-pin encoder connector [3] in the location that has the label 5th-AXIS ENCODER / B-AXIS ENCODER. Use the (4) screws.
Find the location on the amplifier bank that has the B Axis label. Install the amplifier for the fifth-axis drive at this location.
Connect the fifth-axis servo cable wires to the high-voltage terminals on the amplifier:
  • red to RED [1]
  • white to WHT [2]
  • black to BLK [3]
Connect jumpers [4] from the fifth-axis drive to the nearest amplifier on each side:
Connect the 3-pin connector [1] on the B-Axis brake cable to P17 [2] on the I/O PCB.
Connect the 16-pin connector [3] on the encoder cable to Encoder Channel 5 (P21) [4] on the MainCon PCB.
Connect the 10-pin connector [5] on the current-command cable to the Amplifier Channel 5 (P5) socket [6] of the MainCon PCB.
Install the cover plates for the Maincon PCB and I/O PCB.
Push [POWER ON].
Refer to: Next Generation Control - Option Activation Code to enable the fifth axis software.
Rotary - Enable and Disable - NGC
These procedures tell you how to enable, disable, and clear a rotary unit on a machine with the Next Generation Control:
Note: Rotary products equipped with a Sigma-7 motor require software version 100.17.000.2030 or higher for full 4th axis operation.
  • Next Generation Control - Rotary - Enable: Do this procedure after you install a rotary unit. This procedure tells you how to tell the control what rotary unit you installed.
  • Next Generation Control - Rotary - Disable: Do this procedure to temporarily disable the rotary axis while you keep the rotary axis configured.
  • Next Generation Control - Rotary - Clear: Do this procedure when you remove a rotary unit from the machine, and you must install a different rotary unit.
Rotary - Enable
Do this procedure after you install a rotary unit. This procedure tells you how to tell the control what rotary unit you installed. Do this procedure on a machine that has the Next Generation Control. This rotary selection tool replaces Setting 30 and 78 used on CHC controls. See enable Rotary axis - CHC for instructions.
Push [POWER ON].
Push [SETTING].
Select the Rotary tab [1].
Highlight the 4th Axis rotary unit that is installed [1].
Push [ENTER] to Set Axis [2].
 Note: This screen shows the TR310-P4-TLT rotary.
Note:  If your rotary product does not appear in the list, the control may need to update the rotary configuration. Only Haas technicians can update configuration files. Contact your HFO to schedule the update and refer to the Update Rotary Configuration Files procedure.
NOTE: CONFIG FILE NAME INFORMATION
Single axis rotaries require one config file, while dual axis requires two files.
All config file names are broken up into several parts separated by dashes.
The first part is the model number of the rotary unit [1]. This can be found on the serial plate of the unit. Some Rotary units have a dash in their name, that dash may or may not be included in the file name.
The next part of the file name is the P version number of the unit [2]. This can also be found on the serial plate of the unit.
The next part of the files only appears on dual axis Rotaries. The next part is either "TLT" or "ROT" [3]. TLT applies to the 4th axis, and ROT applies to the 5th axis. Single axis rotaries will not have this part.
The last part of the name is an R at the end. Using this configuration file would make the Rotary turn in the opposite direction.
Push [A], [B], or [C] to select the Axis Configuration [1]. By default, the 4th axis is set to A.
Push [4] / [5]  to change the physical connection [2].
Push [M] , [S] , [I] to select Rotary relation to change the physical connection [3].
Push [T] / [P]  to Set Loaction [2].
For this example, the Axis Configuration is Axis A [1], and the Physical Connection is the 4th axis [2].
 Note: To use the Tool Center Point Control (TCPC, G234) or Dynamic Work Offset (DWO, G254), make sure the position of the rotary unit is the same as the illustration on the display.
Push [ENTER].
This example sets the TR310-P4-TLT to the A Axis [1].
 Note: The rotary changes do not go into effect until you push [F3] (Apply Rotary) [4]. Go to Step 6 if you are ready to press [F3] (Apply Rotary).
Select the 5th Axis rotary unit that is installed [2].
Push [ENTER] to Set Axis [3].
 Note: This screen shows the TR310-P4-ROT rotary.
Push [ENTER].
This example sets the TR310-P4-TLT to the A Axis and set TR310-P4-ROT to the C Axis[1].
Then, push [EMERGENCY STOP].
Push [F3] to Apply Rotary [2].
Go to the next step to use TCPC or DWO if you do not use TCPC or DWO, power cycle the machine.
The A and C Axes are shown under Position [3].
To use TCPC or DWO:
Push [F4] to Enable TCPC/DWO [3].
Confirm TCPC/DWO Configuration [1] shows in the display.
Ensure the rotary unit's position is the same as the illustration in the display.
Push [ENTER] [2] to confirm.
TCPC/DWO Disabled changes to TCPC/DWO Enabled [4].
Push [F3] to apply the Rotary.
Power cycle the machine.
Push [ZERO RETURN]. Start with the X Axis.
 Caution: If the A axis (tilt) moves more than 20 degrees past the home position,
Push [EMERGENCY STOP] to prevent damage. Ensure you selected the correct config file for your rotary model, 4TH AXIS ENABLE, and 5TH AXIS ENABLE.
Jog the machine table to the maximum travel in each axis.
 Caution: Ensure the cables do not get caught on the table or crushed between the table and the enclosure to prevent damage.
Rotate ("tilt") A axis to get access to the T-Nuts.
Install the remaining studs, washers, and nuts.
TRT70 Only:
Enable Setting 53 Jog W/O Zero Return.
Jog the A axis (tilt) until the slots are aligned as shown.
Jog the B axis (rotary) until the notches are aligned as shown.
Push [ZERO RETURN], [A].  Wait for the axis to find the home position.
Push [ZERO RETURN], [B].  Wait for the axis to find the home position.
 Caution: Make sure the cables do not get caught on the table or get crushed between the table and the enclosure to prevent damage.
Disable Setting 53 Jog W/O Zero Return.
Rotary - Disable
This procedure tells you how to disable a rotary axis. When you disable a rotary axis, you can prevent it from moving but keep it configured.
A rotary axis is enabled when it has a mark [3] to the left of the rotary axis. The rotary axis is enabled in the Position [4] screen.
Select the rotary axis [1] to disable.
Push [ENTER].
The mark for the rotary axis goes away [5].
The axis goes away from the Position screen [6].
If necessary, do this step again for the other rotary axis [2].
Note: If you intend to lift the rotary, see the lifting instructions in the rotary manual 3.1 Lifting Instructions.
Rotary - Clear
This procedure tells you how to clear a rotary axis configuration from the Current Rotary Selection. Do this procedure when you remove a rotary unit from the machine, and you must install a different rotary unit.
Push [EMERGENCY STOP].
Push [ORIGIN] to clear the rotaries.
The$Clear Rotary Configuration [1] display shows.
Push [ENTER] [2].
The rotary configurations are cleared from the rotary selection.
Warning: If you are removing a rotary, it must be connected to
11.3 Reverse Rotary Direction Setup
Reverse Rotary Direction Setup - NGC
Revision B - 05/2026
This procedure tells you how to load rotary files to reverse the rotary direction of your Haas rotary. The files supplied only apply to available Haas rotaries.
This procedure applies only to Haas rotaries on machines with software version 100.16.000.1030 and higher.
Note: Software version 100.21.000.1130 and later will not come with reverse rotary files.
This procedure will work for previous software versions that did not come with the desired reverse rotary file. Verify that your software is compatible with the rotary you wish to install. See Rotary - Compatibility and Servo Motor Configuration Identification for more information about rotary compatibility.
Updated
Download and extract the reverse rotary direction files.
Note: The complete reverse rotary folder must be loaded. Do not load an individual reverse rotary file from within the folder, as the procedure will not complete correctly.
Download Rev_User_Rot.zip
Find your rotary model in the extracted folder and copy it to a USB memory device.
Insert the USB memory device with the rotary configuration file into the USB port on the control pendant.
Press [LIST PROGRAM] and navigate to the USB tab [1].
Select your reverse rotary file [2]. Press [ENTER].
Note: The reverse rotary files that are loaded with this procedure will have an R in the Name column. These files will have the same name in the Model column as normal rotary files. Reverse files preloaded with the software will end with -R in the Model column.
Press [F2] to copy the reverse rotary file.
Navigate to User Data [3] on the Copy To screen.
Press the [RIGHT] CURSOR arrow to enter the User Data directory.
Navigate to the My Rotary directory.
Press the [RIGHT] CURSOR arrow to enter the My Rotary directory [1].
Press [ENTER] [2] to copy the rotary configuration file to this location.
Press [SETTING].
Navigate to the Rotary tab [1].
Type the model of your rotary and press [F1] to search. This example uses TRT210-P20 [2]. Reverse rotary files have the letter “R” in the Name column. Normal rotary files will be blank in the Name column.
Your reverse rotary file [3] is in the Select New Rotaries page.
Highlight the rotary files you want to activate and press [ENTER] to pull up the Select Table Orientation screen.
In the Select Table Orientation [1] screen.
Press [A], [B], or [C] to select the Axis Configuration [2].
Press [4] or [5] to change the physical connection [3].
Press [M], [S], or [I] to set the rotary relation as master, slave, or independent [4].
Press [T], [L], or [N] to set the location of the spindle at either the table, live tool spindle, or main spindle [5].
For this example, the Axis Configuration is Axis A [2], the Physical Connection is the 4th axis [3], the relation is independent [4], and the location is the table [5].
 Note: The rotary direction must match the rotary direction on the image to use Tool Center Point Control (TCPC, G234) or Dynamic Work Offset (DWO, G254).
Press [ENTER] [6].
Press [F3] to Apply the Rotary.
Cycle the power on the machine when you are prompted.
Jog the axis to make sure it operates correctly.
